Where the hell is my oil filter? 4AGZE?
Postby DB4G63 » Mon May 29, 2006 5:17 pm
Just a small question. Ive been doing some Google searches trying to locate an image that clearly shows an AE101's 4AGZE's oil filter position. Last time did an oil change couldnt find the damn thing for looking. I guess the car being so low didnt help getting under it either.
Im aware it somewhere on the firewall side since its a RWD motor mounted backwards but where?? Its quite a small filter so finding it isnt easy either.
If anyone knows or has a pic it would be greatly appreciated.
Also how hard is it to change a dash backlight bulb?
"If I'm a child that means you're a pedophile, and I'll be damned if i'm going stand here and take this from a pervert."
Wheels: AE101 1993 GTZ Trueno (S/C)
DB4G63
Postby Dell'Orto » Mon May 29, 2006 5:19 pm
If its like the other 4AGE's its at the front, under the exhaust manifold.
Postby flat_0ut » Mon May 29, 2006 5:34 pm
took me ages to find mine too :P hidden in there. damn 4age!
flat_0ut
Postby aesc » Mon May 29, 2006 5:51 pm
Dont burn yourself trying to get it off :lol:
EX AE101 owner
2013 Ford Focus ST
aesc
Postby B1NZ » Mon May 29, 2006 6:41 pm
under that big flappy thing in front of the front windscreen, just behind the headlights :lol:
Subaru GF8 Wagon
Subaru GC8 rally car project
B1NZ
Postby gordon77 » Mon May 29, 2006 8:17 pm
aesc wrote:Dont burn yourself trying to get it off :lol:
yes yes i have scars on my wrist from my old 4age :twisted:
What is RR?
gordon77
Postby DB4G63 » Mon May 29, 2006 9:05 pm
Woah thanks guys!!
At the front? people keep telling me its at the rear.
Ill take a look tommorrow
:D thanks!
DB4G63
Postby bluemaumau » Mon May 29, 2006 9:13 pm
look man, its a big cylinder on the block!
its under the exhaust manifold,
yes let the engine cool down also.
Postby Alex B » Mon May 29, 2006 10:05 pm
Its mounted the same way around as it is in the aw's...
Postby CozmoNz » Mon May 29, 2006 10:43 pm
Yeh, pointing towards the front of the car :P
Rayne For President!
CozmoNz
Re: Where the hell is my oil filter? 4AGZE?
Postby Ae92typeX » Mon May 29, 2006 11:28 pm
DB4G63 wrote:...Im aware it somewhere on the firewall side since its a RWD motor mounted backwards but where??...
not that it matters now, but filter mounting side is not dependant on if the engine was origonally rwd or fwd. (just for your future info)
Ae92typeX
Postby DB4G63 » Tue May 30, 2006 12:44 pm
Thanks guys! that helps alot
After much google image searching I found this great pic showing exact location....magic!
DB4G63
Postby mr pad » Tue May 30, 2006 2:03 pm
wear a big glove. and if you use fram, they are a shit load easier to get off as they have a grippy grip edge thing.
mr pad
Postby B1NZ » Tue May 30, 2006 5:52 pm
mr pad wrote:wear a big glove. and if you use fram, they are a sh*t load easier to get off as they have a grippy grip edge thing.
yeah man, thoseblack grippy bits are mint :idea:
Subaru GF8 Wagon
B1NZ
Postby slighty_sykotic » Tue May 30, 2006 7:51 pm
But the fram doesnt have enough "reach" for my 4age...
its a 1st gen gze block, (aw11), and its got the sandwich plate thingee removed. The genuinue toyota filter only screws on about a turn, the fram one can't get a good grip.
--Sykotic
slighty_sykotic
Postby Ae92typeX » Tue May 30, 2006 8:49 pm
slighty_sykotic wrote:But the fram doesnt have enough "reach" for my 4age...
--Sykotic
u mean the filter thread? you could invest in a slightly longer one. I wouldnt feel secure with a one turn tight filter myself.
Ae92typeX
Postby slighty_sykotic » Tue May 30, 2006 11:41 pm
Yup, thats exactly what I mean.
Its a nice big corse thread, the reckon one turn is ok with it (has been so far).
(Had to remove the plate becuase the turbo manifold is too close..)
--Sykotic
slighty_sykotic
