Looneys new turbo :)
Postby slighty_looney » Tue May 30, 2006 3:40 pm
I just got my hands on a turbo thanks to trademe :) still got to get it posted down here so i dont have it yet but hopfully early next week it will b here, its a td04 off a NZ New GDB WRX that had travelled only 50,000ks
FC3S
Robinson Steel Fabrications
Current Ride: 88 rx7
Project: viewtopic.php?t=88412
Discussion: viewtopic.php?t=88413
slighty_looney
Postby Dell'Orto » Tue May 30, 2006 6:54 pm
One day when it grows up, it hopes to be a real turbo :D
Postby dotdog » Tue May 30, 2006 8:37 pm
My starlet has a bigger turbo on it than that LOL
dotdog
Postby NILPSI » Tue May 30, 2006 8:48 pm
HAHA even my car has a bigger turbo than tha............ oh, hang on :P
2017 Triton - The "free supplied by work" daily
2018 Camry V6 - The actual daily
1997 Trueno BZ-G - The Garage Queen
1997 Supra SZ-R - Now with added boost!
NILPSI
Postby slighty_sykotic » Tue May 30, 2006 10:29 pm
lol, its bigger than mine.... well, its shiner than mine....
leave the td04's alone, they rock :D
*hugs his dead td04*
--Sykotic
slighty_sykotic
Postby NILPSI » Wed May 31, 2006 6:41 am
slighty_sykotic wrote:leave the td04's alone, they rock :D
As paperweights :P
NILPSI
Postby slighty_looney » Wed May 31, 2006 12:32 pm
haha come on td04s rnt that bad, atleast they spool quick :lol: its good for what i want anyway if i got a bigger turbo, id run more boost, then my engine would die
FC3S
slighty_looney
Postby Dell'Orto » Wed May 31, 2006 1:48 pm
Well actually, 15psi from a TD05 would be a hell of a lot less stressful on it than 15psi from a TD04 ;)
Postby slighty_sykotic » Wed May 31, 2006 1:55 pm
But they so cute!
slighty_sykotic
Postby NILPSI » Wed May 31, 2006 11:10 pm
So thats what you guys are looking for in a turbo? something "cute" :?
I reakon my car would keep up with yours if you put a TD04 on it :P
NILPSI
Postby Dell'Orto » Wed May 31, 2006 11:13 pm
I think an SC12 would be a better proposition :?
Postby bluemaumau » Wed May 31, 2006 11:37 pm
Mmm, Boost wrote:Well actually, 15psi from a TD05 would be a hell of a lot less stressful on it than 15psi from a TD04 ;)
exactly, itll shit itself
Postby slighty_sykotic » Thu Jun 01, 2006 12:38 am
NILPSI wrote:I reakon my car would keep up with yours if you put a TD04 on it :P
Prove it next week then :)
On my 8psi on my td04 it will kill yours.
They arn't THAT bad if you don't overboost them.
slighty_sykotic
Postby Loudtoy » Thu Jun 01, 2006 11:50 am
No it won't, it might just beat it if your lucky, see the problem with the td04 is that while they are greate on 4efte's they aren't so good on 4agte's funnily enough because they spool so quickly, another thing about spooling quickly unless you got some weird stuff happening it's going to kill your top end power which is what the 4age's are geared for so imho don't waste anymore money on tdo4's find yourself a nice td05 or similar size turbo put that on at 8psi and be amazed at the difference.
BTW when i chucked a td04 at my missus old starlet had full boost by 3.2k rpm and had boost creep issues at about 4k till i got the wastegate ported so if your still running it with only the internal wastegate another thing to think about.
Oh lastly i hope you like your quick spool up time full boost by circa 2.3k but run out of puff at 5k doh. You won't see it so much on power graphs dyno etc but you will notice it on the road where it's still acclerating but just not as fast as down low till you change gears again
TS Member sine 2001
Prado To tow stuff with
Rodeo to do work stuff in
Loudtoy
Postby slighty_sykotic » Thu Jun 01, 2006 3:20 pm
wah?
Your serious... You think a blacktop will beat a a 4agte...even WITH a td04..
Seriously...
And its externaled, so no boost creep issues.
I releise that they arn't the best turbos, but its a street driven car, and they are cheap as hell.
--Sykotic
slighty_sykotic
Postby slighty_looney » Thu Jun 01, 2006 5:15 pm
yea its only for street use, for the price i got that turbo for, for that low k's its worth all the money i pay for it, im not planning on building a drag car just making my silvertop abit more powerful :D
FC3S
slighty_looney
Postby slighty_looney » Thu Jun 01, 2006 5:16 pm
and im sure the 2004 wrx it came off wasnt much of a slouch ever
FC3S
slighty_looney
Postby Dell'Orto » Thu Jun 01, 2006 5:32 pm
The 2004 WRX you got it off also had a decade of development and 400cc's over your car ;)
By all means, stick with the TD04...but you're seriously restricting what you'll be able to achieve.
Postby Dell'Orto » Thu Jun 01, 2006 5:34 pm
slighty_sykotic wrote:wah?
Seriously...
--Sykotic
Its only gonna make 150fwkw MAX, and more than likely only around 130ish. The biggest advantage will be the good gain in low end torque.
Postby bluemaumau » Thu Jun 01, 2006 6:04 pm
why do you think the guy with the wrx got rid of it :wink:
Mmm, Boost wrote:but you're seriously restricting what you'll be able to achieve.
true that
Return to Palmerston North / Central North Island Region
