4 agte oil feed
4 agte oil feed
Postby trdfxgt » Sat Jun 03, 2006 10:06 pm
my turbo is almost set up but i having some teething issuses i have pluged the oil feed into the block but its got way to much pressure its over flowing the turbo has anyone else had this problem if so how did you solve it ??
trdfxgt
Postby Bazda » Sat Jun 03, 2006 10:09 pm
what size line did you use and what size return did u use
Postby trdfxgt » Sat Jun 03, 2006 10:12 pm
got the same size line as my skyline not sure of the exact size and the return is the same size as the turbo came with
trdfxgt
Re: 4 agte oil feed
Postby Crucible » Sun Jun 04, 2006 1:05 am
trdfxgt wrote:my turbo is almost set up but i having some teething issuses i have pluged the oil feed into the block but its got way to much pressure its over flowing the turbo has anyone else had this problem if so how did you solve it ??
how do you mean "overflowing" the Turbo? as its flowing into the housings or leaking at the fittings? or flanges? what you mean?
Crucible
Real Life Mechanic
Postby trdfxgt » Sun Jun 04, 2006 10:37 am
its pumping to much oil into the turbo causing oil to leak past the exhaust wheel seal and smoke like crazy i know its not a blowen turbo as iv tried 3 seperate turbos on it which all do the same thing also the oil is seeping through the topfeed screew surley someone else must have had this problem before
trdfxgt
Postby EVLGTZ » Sun Jun 04, 2006 11:20 am
pretty common problem
you'll either need to fit a restrictor in the oil feed line or goto the smallest feed line you can get away with or even do both.
As for return line, do the opposite, go larger. Its not coming out at some crazy angle and having go up etc is it?
Someone on here will be able to provide exact sizes for ya
EVLGTZ
Ex 4AGZE AE82 - 14.2@163km/hr
EVLGTZ
Postby trdfxgt » Sun Jun 04, 2006 11:25 am
im sure the return is fine i used commin sence to figure gravity and size would help the return so what do people use to restrict the feed line ????
trdfxgt
Postby Crucible » Sun Jun 04, 2006 12:04 pm
I just got mine up and running, using -3 supply and 19mm return, Its a bush turbo, my supply taps into a flange, Im am getting very slight leakage past the gasket im using exhaust flange stuff with sealant on the outer edge, Ive noticed some guys tap the fitting straight into the housing, maybe to avoid this problem? Some other guys may be able to shed more light on the subject.
Crucible
Real Life Mechanic
Postby Caveman » Sun Jun 04, 2006 12:04 pm
I think you need a 40 thou restrictor on the feed.
Else too much oil gets in the bearing housing and goes past the seals.
BB dont have that problem.
AW11 Track Toy
Formerly known as 1998
Caveman
Postby evil_si » Sun Jun 04, 2006 12:20 pm
i usually use either 5/8 or 3/4 drain lines. and as close as i can to the top of the sump.
i use 1/4 supply lines with 9/16 jic fittings, and never had a problem.
what turbo is it? skyline ceramic t3?
evil_si
Postby trdfxgt » Sun Jun 04, 2006 12:37 pm
i have the return close to the top of the sump the turbo is a air research m10/garret t2 its not ceramic
trdfxgt
Postby craigt » Sun Jun 04, 2006 7:24 pm
You probably need a restrictor in the oil feed, try 3mm. Some of the Nissans go as small as 1.8mm I think
If it doesn't fit, force it.
If it breaks it needed replacing anyway!
AE101 4AGZE
KP60 4AGTE project
craigt
Postby Andy from the block » Sun Jun 04, 2006 9:59 pm
If you havent already, then get another rocker cover with the outlet for
releiving crankcase pressure, or get your cover modified with another
outlet. Definately helped with my turbo setup, doenst smoke at all after
I got another rocker cover outlet and got a 2mm restrictor installed
on the oil feed.
Andy from the block
Users browsing this forum: Bing [Bot] and 19 guests
