I currently have a fwd waterpump on my 4age/ke35 with the thermostat set up in completely the wrong place etc etc.
I've got a rwd waterpump housing, thermostat housing and lines but no rwd waterpump pulley.
can I use the rwd waterpump and thermostat housing, but keep my fwd waterpump and waterpump pulley? or will these parts not bolt together properly?
cheers.
4age waterpump fwd vs rwd compatibility
- l1ttle_d3vil
- Toyspeed Member
- kingcorolla
- Toyspeed Member
yeap they will go together no probs. But if your front cover starts leaking in future must replace with another FWD unit.
the rwd front are differnt and stick out further due to the viscous fan
1983 Carina AA63 4age
- l1ttle_d3vil
- Toyspeed Member
yea, the engine was originally a fwd converted to rwd.
are all fwd bluetop waterpumps the same then? I don't know exactly what mine is out of, so would one out of an ae82 bluetop do the trick?
beeker: that depends if the waterlines in your ae86 had been converted to rwd everything or if you were still running the fwd pump and pulley etc.
- l1ttle_d3vil
- Toyspeed Member
kingcorolla wrote:yeap they will go together no probs. But if your front cover starts leaking in future must replace with another FWD unit.
is it a common problem with these leaking?
the whole reason im changing my waterlines is because my waterpump started leaking on my way to taupo on the weekend so i've got to pull the pump etc off to check it all out and may aswell set it up correctly while its all apart.
from what i can see so far its just leaking from the top of the waterpump somewhere; is it just a seal thats gone or something?
and im using an electric fan, so the fan on the waterpump doesn't matter.
- suberimakuri
- Toyspeed Member
- Contact:
