Supercharger Oil
Supercharger Oil
Postby AE82 FXGT » Tue Jun 13, 2006 5:51 pm
Hey all, I recently bought a levin gtz. Now I've done all the usuals when I get a new car (oil, air, fuel filters, coolant and the oil itself). Now I've been told that I should change the Supercharger oil, I looked into it and bought some oil (50ml) from Toyota and it came with a syringe some tube and the oil itself. Now after searching these forums and scouring google and looking at the car itself I still can't figure out how to change it.
Little help?
AE82 FXGT
Postby Rick » Tue Jun 13, 2006 6:04 pm
In the pic below you will see the dip stick, and below that is the drain plug, undo, drain the oil out, refit plug and fill with new oil. If you can I would remove the rear housing (Left hand side in the pic) and give it a good clean out as they have a tendency to build up muck in there.
Postby AE82 FXGT » Tue Jun 13, 2006 6:08 pm
Man, I wish my dip stick was that easy to see.
So when it's on the car is the dipstick on the firewall side of the engine bay?
AE82 FXGT
Postby Rick » Tue Jun 13, 2006 6:19 pm
AE82 FXGT wrote:So when it's on the car is the dipstick on the firewall side of the engine bay?
Yes, if its in a FWD
Postby AE82 FXGT » Tue Jun 13, 2006 6:31 pm
Sweet so does anyone know how much oil they take?
I read old mr2 ones took 130ml's is that the same supercharger?
AE82 FXGT
Postby Mr Revhead » Tue Jun 13, 2006 8:03 pm
yes it is
130ml from empty
just be glad u dont have an aw11! thats an underneath job :?
what sort of supercharger?
Postby moose.cannon » Thu Jun 15, 2006 3:57 pm
Hi, what sort of superchargers are usually on levins? roots, centrifugal or twin screw?
how do I turn this on ?
moose.cannon
Postby Mr Revhead » Thu Jun 15, 2006 3:59 pm
roots
