LVV certification is not required provided that:
the OE gearbox cross-member has not been heated, cut or welded, and
the OE gearbox cross-member mounting to the OE body or chassis members is
unchanged, and
no replacement gearbox cross-member is used, and
the OE drive-shaft(s) is un-modified, and
no substantial modifications have occurred to the floor or gearbox tunnel area, other
than provision for gear-shift mechanism.
celica_tommo wrote:bullshit...
have a read:
celica_tommo wrote: no substantial modifications have occurred to the floor or gearbox tunnel area, other
celica_tommo wrote:RWD/4WD Nissans I have no knowledge of but making a big assumption here that Zyros is talking about a FWD Toyota I would be 99% sure that you could stay within those constraints when doing your conversion
matt dunn wrote:celica_tommo wrote:RWD/4WD Nissans I have no knowledge of but making a big assumption here that Zyros is talking about a FWD Toyota I would be 99% sure that you could stay within those constraints when doing your conversion
um, yeah.
Cant help without knowing the car.
Converting a gearbox????
And yea, it is the skyline, i cant stand automatics
RS13, did the crossmembers fit when you done it?
Zyros wrote:Yeah, i have a mate who can give me some old parts (R33 turbo stuff) which im going to throw into the R33.. seems worth it seen i got the car dirt cheap and its excellent condition!
Have to run low boost though, dont think an R33 pistons are going to handle much more than 5psi..
Kinloud wrote:Dumb Comment maybe, but...
It looks like you might be able to turn the crossmember 180 degrees and maybe it would line up better with the holes in the chassis?
Probably the pics don't show something in the way that prevents this but it might be worth a try?
