Adamal wrote:SR20DET's came with T25's and T28's.....
l1ttle_d3vil wrote:apparently the M24's come off non gtir sr20dets...
RS13 wrote:...everyone wanting to slap one on their CA18, lol..
Silvertop wrote:I've never seen / heard of an M24 coming from an SR20DET. You either get a T25G, T28 or T28(bb) on non-GTIR SR's. T25 turbos come from CA18DETs.
l1ttle_d3vil wrote:Silvertop wrote:I've never seen / heard of an M24 coming from an SR20DET. You either get a T25G, T28 or T28(bb) on non-GTIR SR's. T25 turbos come from CA18DETs.
it was referred to as an "m24 t25g"...sorry; thought the t25g was irrelevant my bad
bluemaumau wrote:if you wanna go vf series go vf8 as its apparently just a little bigger
drftnmaz wrote:i'd run a vf8 over a vf10 for sure...
i run a vf10 on my 4k and it spools by 3000rpm so a vf8 will be sweet on a 1600 twin cam if you make a decent flowing manifold
crnkin wrote:choking the engine relatively speaking 1998, is like saying petone is further from auckland than lower hutt.
crnkin wrote:drftnmaz wrote:i'd run a vf8 over a vf10 for sure...
yeah yours has smaller ex housing tho?
Run vf10 or td04, i havent seen a vf8 for sale in a while. Vf10's are like 80 bucks, you cant go wrong.
choking the engine relatively speaking 1998, is like saying petone is further from auckland than lower hutt. The difference in top end wouldnt even be noticed on a dyno i presume, the difference is more legligible than between a 200km stock bluetops power and a 250.
vf10, less taking more doing
1998 wrote:however a vf10 will choke relative to a vf8, although its not very much its something to keep in mind when going for peak HP.
