On a standard 4agze (ae101) is the air temp sensor before the supercharger, after the supercharger (hot) or after the intercooler.
Its the one that mounts at the bottom of the in/manifold, (left side lower corner), I just welded a nut to the boost pipe running to the throttle body and remounted it there when I fitted the n/a mani.1998 wrote:On a standard 4agze (ae101) is the air temp sensor before the supercharger, after the supercharger (hot) or after the intercooler.
True-No-Turbo wrote:Its the one that mounts at the bottom of the in/manifold, (left side lower corner), I just welded a nut to the boost pipe running to the throttle body and remounted it there when I fitted the n/a mani.1998 wrote:On a standard 4agze (ae101) is the air temp sensor before the supercharger, after the supercharger (hot) or after the intercooler.
Yup, thats right! after the cooler1998No-Turbo wrote: So after the intercooler? It makes sense to put it there too
