AE82 FXGT wrote:So do you know if anyone has done this sort of thing before?
Will it have any adverse effects on anything else?
1998 wrote:The ECU controls the supercharger relay.
Just intercept the wire (you can look up the colours and pinout on club4ag) and either
- earth relay (the wire not going into the ecu) - supercharger always on
- bridge the wires - ecu controlled supercharger
- break the circuit - supercharger always off
You should be able to get a switch that does this for cheap from electrics store
CozmoNz wrote:1998 wrote:The ECU controls the supercharger relay.
wanna make it easier for some people and just do a wiring diagram?
Quint wrote:your car will have no top end power if you turn off its boost as it'll have a low compresson without the S/C to compensate/raise it. EG. no go above 3g rpm
1998 wrote:someone correct me if im wrong, maybe 100k is too much on the resistor?
