The reason the Altezza guys wanted to run the SAFC, was to lean out the factory fuel at high RPM...
As they run a bit rich, as a safety margin.
They did this, and gained some HP.
However after a week, it was back to normal.
I think there was dyno plots to prove it, but I cant remember.
And regarding the WOT comments not using the sensors....
I think that they do adjust the WOT map, but indirectly.
At partial throttle conditions, the ECU richens/leans it out on the fly.
However if it can establish a trend over a period of time (Eg. constantly having to richen it at 3000rpm)
Then it bumps up the fuel map, so it doesnt have to go through the lean/rich cycle anymore.
If it is capable of doing this, I'd imagine it has the capability to alter the WOT map as well, based on the revised long term maps which are altered while at partial throttle conditions.
Just because it's running WOT and from a map, instead of the sensor info, doesnt mean that it cant use the sensors to establish trends, and alter the map to suit.
I dont think anyone can say for sure though, either way.
Personally, I think it
does learn, because of:
The autoshop101 documents saying that this is how it works
The altezza guys having their AFCs tuned out
And some things that I noticed with my redtop engine.
The pipe that my AFM is in, is bigger than the standard cross sectional area of the pipe.
When I first started it, it ran rough as guts, and would hesitate and splutter when the throttle was opened.
However after running for 1/2 an hour or so, it came right.
After this I turned the car off.
Next time I started it, it fired up and idled and revved fine from the start.
After this I disconnected the battery to work on something, and when I started it up again it was running rough again.
I took it for a drive, and it was hesitating slightly again. (only drove for a few mins)
The next time after that, it was running great when I drove it.
Perhaps there is some other reason for this, but the facts seem to point towards an ECU that adjusts itself.
However this is a
relatively modern engine, AFAIK one of the first to come with DFI, VVTI, etc.
It wouldnt surprise me if it got an IQ increase to suit the rest of the motor.
I also wouldnt be surprised if earlier ECUs didnt have these capabilities, especially something made when commonplace fuel injection was in its infancy.
(And at a time, where emissions regulations werent so strict.... Why spend 50x longer making an ECU that performs 3% better?)
I also wouldnt be surprised if the increased intelligence of ECUs is not only thanks to better hardware, but also increased technology, eg. Toyota being able to make complex simulators of engines, to help design and 'debug' their ECUs. (Which perhaps becomes more necessary, as they become more complicated?)
However all of that is mere speculation, dont quote me on it.
