funky sounds in my ae101 S/S
Postby Dirtbag » Thu Jun 22, 2006 7:19 pm
Firstly, get a kinda dull creaking as i set off or come to a stop, right as i start/stop rolling. Also it creaks over bumps sumtimes, the guys at ilam toyota told me this is the lower link arm? They said 120 for each side to get these replaced. Also, I am pretty sure the clutch is SHAGGED, how much work is it to replace a clutch? What kinda prices am i looking at for the clutch? (any ballpark figure) Ive heard around 400.
Car is ae101 gtapex superstrut
AE101 GT-APEX Superstrut
My profile!
Dirtbag
Postby KinLoud » Thu Jun 22, 2006 10:10 pm
Creaking noise? Often in Superstrut cars the creaking isn't the lower link arm. I've driven a GTZ with superstrut with totally rooted lower link arm and it didn't make a noise! It just wandered across the road!
If the lower link arm is shagged - only put in toyota genuine new!!!
Anything else wears out in about 5,000km!!!
Cost might be a bit more but you won't regret it.
To check the lower link arm:
jack up the front and take the wheels off
using both hands, grab the strut at the bottom of the spring and try to twist the suspension around.
It should not twist at all
If it does twist, look at the small lower link arm and you will see the freeplay - this means that it needs replacing.
Toyota new ones last about 100,00km
Ken
Ham
021 408 863
Postby Ae92typeX » Thu Jun 22, 2006 10:30 pm
depending where you go and clutch fitted, ballpark of $350-600
Ae92typeX
Postby Dirtbag » Thu Jun 22, 2006 11:46 pm
The guy said that the stuff inside the box was stuffed
Just had the balljoint on the arm to the right of that box reconditioned, but creaking was there before hand.
My profile!
Dirtbag
Postby Mr Revhead » Fri Jun 23, 2006 10:21 am
the top ball joint also goes 43350 in that pic.
and the rear arm where it bolts to the body
Postby Dirtbag » Fri Jun 23, 2006 11:49 am
Mr Revhead wrote:the top ball joint also goes 43350 in that pic.
I got new shocks from you last year around november, they included those top ball joints, so I hope they havent gone just yet :? And by rear arm you mean the 48068/9?
My profile!
Dirtbag
Postby Mr Revhead » Fri Jun 23, 2006 12:13 pm
oh ok.
is it lowered?
yep thats the bit
Postby Dirtbag » Fri Jun 23, 2006 12:58 pm
Ive never figured that out, it looks slightly lower, but I have always put that down to being superstrut (im mainly comparing with normal gtapexs) Whats a good indication if its lowered? I am pretty sure the springs looked standard when i replaced the shocks.
My profile!
Dirtbag
Postby Dirtbag » Sat Jun 24, 2006 5:50 pm
Would lowered on the superstrut cause problems?
Is there anyway to check the condition of the lower link arm/check if it is whats causing the squeeks other than replacing it and seeing what happens?
My profile!
Dirtbag
Postby Mr Revhead » Sat Jun 24, 2006 6:02 pm
maybe can do if too low.
it can be hard....
best way iv found is put it on a 4 post hoist and get under it
get some one to swing on the car and bounce it up and down, then listen/feel for creaks etc.
Postby Dirtbag » Sat Jun 24, 2006 6:07 pm
Whats stock height for the car?
And it squeeks with roughish bumps, anyway to simulate these apart from a rolling road or sumthing?
My profile!
Dirtbag
