Fixed the old supra up all good, running like it should, the low down turbo lag isn't nearly as bad anymore. Except i got one odd problem that has popped up due to it.
At higher rpm say around 5g in 4th the rpm will drop say about a thousand down to 4g, I don't loose any speed or power, still keeps building, the engine doesn't sound like it is loosing a beat or anything, the car also seems to rev a bit high at idle, not sure if thats got anything to do with loosing rpm. anyone got any ideas or places to start?
EDIT: Considered tacho, but as i played around with it mechanically, rather than electronically, i've got a hunch it'll lie in the mechanics.
