Hi guys,
new location for the guide to disabling the VSC in the caldina
Here
sergei wrote:So you are saying that if you flick the switch on the fly, the VSC becomes disabled till next restart, so why not make a push button instead of on/off toggle switch?
WanaGo wrote:So what is this wire you cut exactly? What does it go to specifically, which disables the VSC, but doesnt re-enable it after the connection has been restored?
Is this an input to the ECU or something, and restarting the ECU is required to re-initilise the inputs or something?
I have an electronics background, so would be interested to know.
Thanks
WanaGo
WanaGo wrote:By the looks of the Caldina wiring diagram (thanks to Mr Revhead), that wire is the positive wire of a twisted pair to the stearing sensor. From what it looks like (may be incorrect though), by cutting this wire for over a second, causes the same symptoms as having the stearing sensor go into malfunction - due to no signal for over 1 second. This causes the VSC to shut off due to the stearing sensor being a critical part of the VSC.
There is not alot of information on this diagram, but it looks as though any of the sensors (decceleration, yaw, stearing etc) could be cut and have the same result - but the stearing is probably the easiest to get to and looks as though its the fastest to simulate a malfunction.
On further inspection, resetting the VSC back into normal mode would not be a hard task, it would only require the resetting of the VSC/TRD/ABS/BA computer - which could be done easily. I am not sure how the car would react if this was done while in motion, but how my setup is at the moment with my alarm keeping the ignition circuit/engine computer alive while it kills the rest of the system - a similar approach could be done using a small circuit in the back of the push button/switch.
While I dont need this for my own setup obviously, it would be interesting to see who out of the Auto GTT owners would be interested for something like this.
I know Inane has already looked into all of this - and I dont know how far he got (he may already have been down this road, im not sure).
Inane if you read this, can you post and let me know how far you have got. No point keeping this a secret from everyone now - as it could benefit a few toyspeeders.
I dont want to step on anyones toes, but as I said to inane earier - I am keen as to get a good VSC with on the fly enable, up and running. No point letting my electronics knowledge drift away, its projects like this that keep it in the head.
No doubt this will work for a wide range of auto GTT's and probably GT4's. Possibly more models with VSC too. The wires/plugs may not be the same, but I presume the basic technology will be about the same. It should not be difficult to adapt.
Feedback feedback feedback.
cheers all
WanaGo
Inane wrote:the way it works is instead of actually disabling the vsc you are faking a steering wheel position sensor malfunction, that causes the vsc to disable itself, while keeping the abs functioning.
