4afe cooling system problems.
Postby ollieboy » Tue Jun 27, 2006 12:54 am
On my dads car (1992 Ceres) the temp gauge displays zero while open road driving and only starts to move when driving in a city or when idleing. When you go back on the open road though it goes back to zero. The car is running rich because of this and smoking like a mother father.
What do you guys think it would most probably be. My thoughts are thermostat or water pump. The cars done 180,000kms, is the water pump likely to fail around these km's or should I look elsewhere.
I would try and work it out for myself but it averages 5 degrees a day here and the Ceres is a c*** of an engine to do anything to so want some ideas to try before I go out so I can be quick and not freeze.
ollieboy
Postby Alex B » Tue Jun 27, 2006 2:09 am
thermostat fukd, waterpump rooted would overheat or leak.
Postby Punter » Tue Jun 27, 2006 10:44 am
Yup thermostat.
Punter
Postby bluemaumau » Tue Jun 27, 2006 12:31 pm
yea would those extreme weather condidtions $&#$% thermostats quuickly?
Postby sergei » Tue Jun 27, 2006 12:34 pm
what extreme conditions???
where I come from, in winter we ran cars without radiators or thermostats (just straight pipe) and heater on full all the time....
In fact in hotter weather thermostat would open more often (more wear) than in cold...
The problem with needle on cold most of the time lies in faulty thermostat (or less likely air lock, or faulty sender/guage)
Postby fangsport » Tue Jun 27, 2006 4:15 pm
check themostat, but could very well be an air lock in the heater.
my Levin had what i thought a dodgy thermostat, or over heating due to air pocket in heater (being level with radiator cap).
get front of car up in the air( or on an angle) when topping water up to get rid or air in heater.
turned out the my H/G was blown, pushing air into the heater, and pumping water out the overflow. bubbles only appeared in radiator/overflow when front of car was well above the rear.
fangsport
Postby ollieboy » Tue Jun 27, 2006 7:04 pm
fangsport wrote:check themostat, but could very well be an air lock in the heater.
Yeah, this is exactly what the problem was.
Cheers for your help.
ollieboy
Postby gepsk8 » Tue Jun 27, 2006 7:07 pm
themostat is stuck between 1/3-2/3 open my shitter Leone cough cough did this to. didn't change it as it not worth spending $ on still goes too. eats gas tho.
gepsk8
