Differences in 4K engine mounts
Postby matt dunn » Sun Jun 25, 2006 11:40 pm
Are Starlet 4K engine mounts and KE70 corolla 4K engine mounts the same? Can you use starlet mounts on a corolla?
Also anyone have a KE70 5 speed gearbox crossmember for sale?
Matt
Postby wde_bdy » Mon Jun 26, 2006 11:25 am
From memory (it was a few years ago), I dropped the 4K from a KE70 straight into my KP61 without swapping mounts. However I did have problems putting a 3K in as the lower deck height caused my custom extractors to hit the engine mount. :oops:
Callum
wde_bdy
Postby Loudtoy » Tue Jun 27, 2006 8:13 pm
I know for a fact ke20 and 30 mounts are the same so i can't see any reason for it to be different in a 70, they came out with 4k's standard didn't they?? No to many engine sereis that i know of that change mounts half way through the range apart from 4g63's when they turned the motors around :)
TS Member sine 2001
Prado To tow stuff with
Rodeo to do work stuff in
Loudtoy
mounts
Postby boganboy69 » Wed Jun 28, 2006 9:56 pm
yes kp60 and ke70 engine mounts are diff
DMD MOTORSPORT
boganboy69
Re: mounts
Postby Loudtoy » Wed Jun 28, 2006 10:52 pm
boganboy69 wrote:yes kp60 and ke70 engine mounts are diff
Uh explain possibly with references to how and what you did??
TS Member sine 2001
Loudtoy
