Quint wrote:Hmm another problem is 90% of people don't know how loud 95db is, me being oneI know that the decibel scale isn't linear and it gets quite exponential towards the higher degrees, but other than that. *shrug*
Anyone know of any comparrisons between db and engine?
Eg. straight 6, 3L, 3" exhuast = ?db
snwtoy wrote:Quint wrote:Hmm another problem is 90% of people don't know how loud 95db is, me being oneI know that the decibel scale isn't linear and it gets quite exponential towards the higher degrees, but other than that. *shrug*
There's zero correlation between engine size and noise. A 10cc lawnmower can be louder than a 4000cc V8. It's all to do with the exhaust and mufflers.
And, 95dB does not always equal 95dB - the environment can have a large part to pay. Theoretically your exhaust is louder on a day with high pressure than on a day with low pressure (I think that's the right way round). It's all do do with the density of the air.
Also, any walls, the type of ground (grass/dirt/concrete) etc all have an effect.
VR-4Squid wrote:more important even than that, is the distance from the exhaust it's measured at.
personally haven't seen them, but I know people who have. But a number of euro cars now have valve systems in the exhaust which restrict the flow during cruise in order to reduce the noise output
Mr Revhead wrote:also i think soarers? some thing like that has it
snwtoy wrote:There's zero correlation between engine size and noise. A 10cc lawnmower can be louder than a 4000cc V8. It's all to do with the exhaust and mufflers.
Really! You learn something new every day. Where abouts on the 101 exhaust system are they? I'd like to have a look at one sometime...Mr Revhead wrote:i bet you have seen thempersonally haven't seen them, but I know people who have. But a number of euro cars now have valve systems in the exhaust which restrict the flow during cruise in order to reduce the noise output![]()
ae101 4ages use them, also i think soarers? some thing like that has it
AMAZING! Well, that's my learning for the day done. Time to sleep... Anyone got a 101 I can look at? Or perhaps someone's changing their exhaust and getting rid of that valve? ....Mr Revhead wrote:where the exhausts splits to go to the seperate mufflers theres a valve.
at low flow the gases go to the drivers side muffler
when u nail it the l/h one opens up.
thats why on a cold day you can see the gases coming out of one side only
