But the Meth makes me happy...Jebus wrote:I think you should lay off the meth
How is running water through pipes on the floor of the car going to cool anything?
The idea was to try and get the weight into the middle of the car. So the two smaller might work. But then you're right, you'r offsetting the weight shift/saving by adding more piping and more water, and you'll have a whole heap of piping inside the cabin, which may or may not be an issue.wde_bdy wrote:Why not just relocate the radiator to the rear or even run two smaller ones mounted into the sides of the carwith ducting to feed them. Generally though any weight saving is offset by the longer pipe runs needed. One of the drag cars in this months performance car mag had the radiator mounted behind the motor, but obviously not running for that long so not a big issue.
RedMist wrote:Torsional movement cracking the brasing.
I started with this thought too. I figured mounting a radiator type thingy on the underside. But for the life of me I couldn't figure out how to get airflow across or through the radiator.pc wrote:A relocated radiator might be the best bet.
COG. Hadn't thought of that... But that is another benefit.RedMist wrote:I dont think its such a bad idea. Low COG, utilize the shell as a heatsink. I think the lowering of the COG is more important than fore aft weight distribution.
Three things I can see as being an issue.
High likelyhood of puncture from a foriegn object.
Low airflow as there will effectively be a boundary layer sitting on the bottom of the car.
exactly where my thinking was heading. a heap of vans and people movers duct air from the front, across a horizontally mounted radiator / A/C condenser.HRT wrote:Why not just lay a radiator down flat under the car with a stone gaurd type setup over it and ducting air through it. Keeps weight down low, be a lot easier to fabricate and you know its an efficient unit
RS13 wrote:Most hardcore drag cars don't run radiators, as methanol burns much, much cooler than petrol. I often wondered about modifying the aircon system, so that the block would be filled with refridgerant.. but you'd need to seal the system something wicked!
Nice thought regarding the radiator, but you'd think that if it was a good idea.. someone would've done it already! I like the idea of putting it in the boot, but only as a last-ditch effort to get maximum flow over the i/c or if I really had to.. say, dropping a straight 6 into a KP!
Clearance. A normal radiator plus the inlet and outlet piping would be quick thick. Fine on the underside of a van, but under I would think it would be highly susceptible to taking damage, especially from those errant speed bumps.HRT wrote:Why not just lay a radiator down flat under the car with a stone gaurd type setup over it and ducting air through it. Keeps weight down low, be a lot easier to fabricate and you know its an efficient unit
The sheer logistics of actually "building" this would generally put this sort of idea in the "too hard" basket. Couldn't imagine factory cars doing this. Imagine when the system springs a leak from old age. How do you replace it with minimal fuss? You can't. So I can see this as an idea that is only applicable to a small number of performance vehicles, designed for reasonably specific conditions.RS13 wrote:Nice thought regarding the radiator, but you'd think that if it was a good idea.. someone would've done it already!
Because that would make me a retarded mechanic from the south island...nzae86 wrote:Why not fit an oxygen removal system to your intake ? That way with no oxygen it will stop combustion and prevent heat build up, then no need for a radiator, simple really!
Does that sort of work require certification? I hadn't really considered modifying the floorpan to suit (at least not in this manner)...wde_bdy wrote:If I was going to do it I would run a normal radiator under the car but raise the floor to give it enough ground clearance and duct air to it. I've done similar to my car to fit an exhaust under, sufficient strength can be returned to the floor with minimal weight. Relocating radiators is not a new idea, you just need to find the approach that suits your end goal. I've seen demo derby cars with the radiator and fan mounted in the glovebox area, was surprisingly effective.
Callum
Definitely a possibility. Although the added weight of the extra coolant lines and ducting may reduce the benefits. Also this approach will not benefit the COG, although this may be offset by the improvement in ground effects downforce (I think that's the correct term).sergei wrote:why not mount it in the boot horizontally, with holes in the bumper and shroud to direct air from under the car, through radiator to the back of the car, win-win situation: increases low pressure under the car, using low pressure behind the car, more room at the front of the car, better weight distribution, increased coolant capacity.
