Do I have 100 kw
Do I have 100 kw
Postby samham » Sat Jul 15, 2006 11:40 pm
I know youve had this question before but Im stumped!! Have searched and am comfussed.
I have a 4age, no intake what so ever (had carbs), 7 ribs, external oil drain, red and black lettering.
Is this the 100kw engine?????
I dont know if the head is big or small port, if the head is bigport does that mean tvis 88kw, and if smallports 100kw non tvis.
See Im getting confused again
Can I measure the with of the intake port to tell?
Drive it like you stole it!
disclaimer: do NOT steal a car;-)
samham
Postby Mr Revhead » Sun Jul 16, 2006 12:31 am
external oil drain would suggest small port
Postby Dragger_Dan » Sun Jul 16, 2006 1:10 am
Mr Revhead wrote:external oil drain would suggest small port
What about the adub ones? They had oil drains on them?
If you can take a photo of the ports, or measure them up I'll compare it with some of my gear for you.
Dragger_Dan
Postby Mr Revhead » Sun Jul 16, 2006 1:22 am
aw11 had bluetop and the last had the red top tvis.
so no external oil drain
hence their habit of running bearings when pulling hi revs mid corner
Postby evil_si » Sun Jul 16, 2006 5:17 am
big port intake ports are 65mm across, small port is 50mm.
evil_si
Postby samham » Sun Jul 16, 2006 8:09 pm
thanks for the help,
I mesured the ports and they are 50mm across and are oval in shape.
What about the round shaped ports are they the 100kw ports or are they the tvis redtops.
I looked on the web and they reckon the 100kw motor has all red lettering??
I took a couple of pics have a look at these.
Also if it is a small port does this mean it is the 100kw engine or is there a 88kw smallport head.
YES, I am confussed!!!
http://i88.photobucket.com/albums/k188/ ... MG0237.jpg
http://i88.photobucket.com/albums/k188/ ... MG0236.jpg
samham
Postby FXGTV » Sun Jul 16, 2006 8:31 pm
If its a redtop and it hasn't got tvis written on the intake manifold then its a smallport... or am i missing something? Always seemed pretty simple to me.
1988 r31 TI Skyline.
1982 ra60 Celica (my Aussie Toyota and axle stand warrior).
ex: 1991 Corolla, 1989 fxgt-v, 1985 aw11. 1992 sw20 gt-s. 2002 glxi Lancer wagon (work hack)
next car - another a-dub please!
FXGTV
Postby no_8wire » Sun Jul 16, 2006 8:42 pm
He doesnt have the intake manifold... :wink:
But yes it is a small port from what you have said. 100kw etc yada yada
no_8wire
Postby samham » Sun Jul 16, 2006 8:42 pm
I have no intake manifold as Im running carbs , I bought the engine that way.
So, yeah it could have been simple :D
someone in the know should write a difinitive guide and faq it.
I find those sites on the net great but between them its conflicting a bit??
samham
Postby FXGTV » Sun Jul 16, 2006 9:08 pm
samham wrote:I have no intake manifold as Im running carbs , I bought the engine that way.
Ok, i correct my suggestion to : I am a n00b and i can't read :P
FXGTV
Postby evil_si » Sun Jul 16, 2006 9:23 pm
the intake ports are the oval, and 2 sizes, 50mm and 65mm across, the round ports are obvioulsy exhaust, and only 1 size 30mm diameter.
small port is the 100kw engine with 50mm intake ports
bigport is the 88kw engine with 65mm intake ports
the rocker cover lettering dont mean shit.
evil_si
Postby samham » Mon Jul 17, 2006 5:50 pm
So because its a smallport does this automaticaly mean that it was non tvis?
samham
Postby Brick » Mon Jul 17, 2006 6:07 pm
samham wrote:So because its a smallport does this automaticaly mean that it was non tvis?
no, they come both t-vis and non t-vis
someone correct me if im wrong
Brick
I know Kung Fu
ok
Postby ezy10s » Mon Jul 17, 2006 6:12 pm
wrong! :wink:
none of the small ports ever came with T-VIS
Member #244
Gone fishing until further notice
ezy10s
Postby Brick » Mon Jul 17, 2006 6:13 pm
:lol: why did toyota have to be so difficult
Brick
I know Kung Fu
heh
Postby ezy10s » Mon Jul 17, 2006 6:15 pm
at least we arent having the connecting rod debate again- now that was some mental shit- trying to work out exactly which engines had what rods.
this port stuff is far less complicated thank god
Member #244
ezy10s
Postby Mr Revhead » Mon Jul 17, 2006 6:21 pm
connecting rod debate again- now that was some mental sh*t- trying to work out exactly which engines had what rods.
i still have flash backs to that 8O :? :evil:
Postby AE85coupe » Mon Jul 17, 2006 10:10 pm
That engine is definately a smallport my friend, so yes you have a 100kw engine
AE85 Trueno *For sale*
Details of car here
AE85coupe
Postby sigma » Mon Jul 17, 2006 10:30 pm
Well he did, until he decided to run carbs on it :lol:
1985 MR2 AW11 20v
sigma
Postby AE85coupe » Mon Jul 17, 2006 10:31 pm
sigma wrote:Well he did, until he decided to run carbs on it :lol:
hahahahaha good call!
Details of car here
AE85coupe
