Work wheel valves - where to get?
Postby gmacrae » Mon Jul 17, 2006 5:49 pm
Hey people, after having the most frustrating conversation of my life with some punjab cu.nt at www.work-wheels.co.nz - i decided id drop in to TS to source the info i'm after.
My 18" Work alloys have stuffed valves, these valves are pretty tricky to get your hands on according to a few local people here. Where shoud i look for these oddball wheel valves?
Thanks guys, im >this< close to declaring war on india.
Gene
gmacrae
Postby Silent Knight » Mon Jul 17, 2006 7:29 pm
Contact Pete (THASHZ) he's the local wheel and tyre guy and should be able to help you or at least point you in the correct direction. :wink:
Silent Knight
Postby KinLoud » Mon Jul 17, 2006 9:03 pm
Are you having a problem with the valve stem seals being perished and leaking?
The Workones I sold last week needed new valve stems as someone had put rubber ones on! (see rant below).
I ended up going to a truck tyre place "firestone fleet service" (they go out in their little trucks and replace tyres on big trucks).
They sold me some shiney valvestems that were bent at the right angle!
I had to get some rubber gaskets cut for them as the rubber o rings weren't going to do the job on their own. total cost was about $40 for a set of 4 and $1 each for the rubber gaskets.
A set of valvestems from a mag wheel place was going to cost about $120 and they weren't quite the correct angle either!
The Work wheels had a problem with the valve stems...
they must have been leaking so the previous owner replaced them with rubber valve stems - the standard ones were bent about 60degree angle to poke out the front of the rim... rubber ones are straight and so you couldn't check the tyre pressures without taking the wheels off!!!!!!!!
Ken
Ham
021 408 863
Postby THA SHZ » Mon Jul 17, 2006 11:58 pm
bring me a sample and i will try and get u new shiny metal onesor wotever u require , id say almost 99 % i should be able to source it for u 8) pm me or call me on 2768740 during business hours and ask for pete 8)
Thanks hanre for the plug 8)
THA SHZ
Postby Looonie » Tue Jul 18, 2006 10:03 am
Ooooooooooo we have a local wheel and tyre guy now?
Hook a brudda up :)
I'm needing to find another regular place for my tyre fitments and supply of good 2nd hand tread...
Rumple dee pumple dee doo...
Looonie
Postby GTCRSHR » Tue Jul 18, 2006 1:11 pm
Tha SHZ has indeed be mr tyre and wheel guy for a long time
he indeed is ... THA SHZ :D
Nothing to see here ...
GTCRSHR
Postby THA SHZ » Tue Jul 18, 2006 8:45 pm
y thanku chris ur not so bad urself buddy 8)
and loonie give me a call i wood be glad to help u out ne way i can 8)
THA SHZ
Postby GTCRSHR » Tue Jul 18, 2006 11:14 pm
THA SHZ wrote:y thanku chris ur not so bad urself buddy 8)
now i know why you called me suga plum instead of bro 8O 8O :P :P :twisted: :twisted:
GTCRSHR
Postby THA SHZ » Wed Jul 19, 2006 7:53 am
well i though thts how u liked it cletis , now come over here and give uncle bully a hug eh ? :lol: :twisted: :wink: 8O
THA SHZ
Postby gmacrae » Wed Jul 19, 2006 5:53 pm
Thanks guys, talked to Pete, very helpful guy.
gmacrae
