cosi wrote:I have the air filter off and at one point while I was turning the key over a burst of flames, maybe 5-10cm long came out the throttle body of the manifold. It rumbles, sounds loud and shakes around in the engine bay quite hard. Hope its not stuffed. haha
cosi wrote:although Im not sure what to do if they happen to not be firing?
if they aren't firing it will be either a) because you've got no power going to them or b) because the ECU is stuffed and isn't telling them to fire.
l1ttle_d3vil wrote:maybe they knocked the ecu or something while they had the car? how do you mean the exhaust was connected up? was it welded at all on the car? if it was mig welded they may have forgotten to disconnect the battery which will stuff your computer.
what sort of loom are you using and what ecu are you using etc? i had quite a few problems with my bluetop 4age and one of them was similar to this. where abouts are you located too, could come check it out if you're close enough?
matt dunn wrote:dumb question but,
are all the HT leads in the correct place? not a firing order problem.
cosi wrote:I disconnected the computer and didnt take it down with the rest of the car. I was actually worried that might happen.
Using AE86 engine/box/loom/ecu into a KP61 starlet, got basically everything that I needed from one car. Im in Auckland near Lynfield/Mt Roskill
