crnkin wrote:How can they abuse it?
What we are talking about is stopping the annoying people racing around at night annoying others.
To abuse it, they sit there, and pick every single car that looks like its modified, and then do their thang, then that person has to pay to go get it tested somewhere else, its not like they test it on the spot, sweet, sticker, it can easily be abused. Where does the fee go to, and can they still pinky us when they decide it needs to be tested, and will they give us a fine anywhos? Theres no sticker that says it is too loud and its illegal, so no sticker still should give the benefit of the doubt?
im confuse
slighty_sykotic wrote:BOV are letting air out from the engine that doesnt go through a proper system, like a cat and muffler system, ie, its a emmission reasons that they don't allow the bovs venting in Aussie...
Mmm, Boost wrote:slighty_sykotic wrote:BOV are letting air out from the engine that doesnt go through a proper system, like a cat and muffler system, ie, its a emmission reasons that they don't allow the bovs venting in Aussie...
Yeah, but the issue of them causing extra emissions has been proved BS on more than one occasion.
wde_bdy wrote:Basically any factory turbo system will have a PCV hooked into the intake pre turbo, so when you vent your BOV you are also venting crankcase fumes. Not to mention causing AFM cars to run rich, so it definitely does cause emissions problems.
Callum
Mmm, Boost wrote:A few of the companies did tests (albeit it on non AFM vehicles) and the increase was neglible.
Mmm, Boost wrote:Chelles, I agree with you on the induction noise...some chap in a Honda went past last night, all I could hear was the boooOOOOOOOOOO as it went past,
slighty_sykotic wrote:You should be ok, cause its not going to be comming on boost hard while being held at a certain rpm, so the induction noise should be ok.
Should be..![]()
--Sykotic
Users browsing this forum: No registered users and 37 guests
