3sgte injectors?
3sgte injectors?
Postby themaleman » Fri Jul 21, 2006 5:44 pm
hi, can any1 tell me if its worth replacing my standard 4agze injectors with 3sgte 1's? the engine is stock standard apart from the t3 turbo. is there any point? and also whos should i stay away from when getting it tuned? any help will b greatly apreciated,
manual 80 series cruiser
4agte ae92 Levin
a15 powered sj410
themaleman
Re: 3sgte injectors?
Postby Crucible » Fri Jul 21, 2006 6:43 pm
themaleman wrote:hi, can any1 tell me if its worth replacing my standard 4agze injectors with 3sgte 1's? the engine is stock standard apart from the t3 turbo. is there any point? and also whos should i stay away from when getting it tuned? any help will b greatly apreciated,
Only replace them if your going with a aftermarket e.c.u also. It will run rich if you were to just chuck bigger ones in as the factory e.c.u is still controlling them at the same rate as the 365's. With a link etc the inj pulse can be set by the tuner to give the engine the correct a/fuel ratio.
Crucible
Real Life Mechanic
Postby themaleman » Fri Jul 21, 2006 7:46 pm
yea i have a link. wiring it it this wekend. anyone else have any opinions?
4agte ae92 Levin
a15 powered sj410
themaleman
Postby flygt4 » Fri Jul 21, 2006 7:51 pm
only bother with it if you're going to be turning up the boost until the original injectors run out of puff. best done on a dyno by a pro with a close eye on AF ratios.
i dont really see any point in changing them over for the sake of it if you're not going to be pushing the stockers past their limit.
flygt4
Postby themaleman » Fri Jul 21, 2006 7:57 pm
its going 2 be dyno tuned when the engine is complete, dose any 1 know if the standard injectors are good for around 12psi boost?
4agte ae92 Levin
a15 powered sj410
themaleman
Postby Crucible » Fri Jul 21, 2006 8:03 pm
What sort of power you after? Stock 365s to 200hp - 440s to 200 kw - 550s will give you more than youll ever need.
viewtopic.php?t=48365
This has just been discussed
Crucible
Real Life Mechanic
Postby themaleman » Fri Jul 21, 2006 8:09 pm
well i want 2 give it as much as i can get without having 2 buy a new engine in a couple of weeks! if the standard injectors r all that stand between me and a few more kws, i will get bigger injectors. im trying 2 find out if thats worth doing if the rest of the engine is standard? (apart from being turbo and a link computer) wat do u think?
4agte ae92 Levin
a15 powered sj410
themaleman
Postby themaleman » Fri Jul 21, 2006 8:16 pm
and cheers 4 that link. it was very helpfull. think ill get a set of 440's and b done with it. thanks 4 the help
ohh last question, do vr4 440's fit the 4agze?
4agte ae92 Levin
a15 powered sj410
themaleman
Postby Crucible » Fri Jul 21, 2006 8:26 pm
themaleman wrote: do vr4 440's fit the 4agze?
Yes they do, ill have some 2jzgte stock 440s for sale in a day or so, will just need to confirm they will fit gze rail. if your keen Pm me.
sweet
Crucible
Real Life Mechanic
Postby themaleman » Fri Jul 21, 2006 8:46 pm
hey would GTIR (RNN14) 440cc Injectors fit a 4agze?
4agte ae92 Levin
a15 powered sj410
themaleman
Postby Crucible » Fri Jul 21, 2006 9:07 pm
themaleman wrote:hey would GTIR (RNN14) 440cc Injectors fit a 4agze?
SR20DET injectors are way differant.
Crucible
Real Life Mechanic
Postby slighty_sykotic » Fri Jul 21, 2006 9:10 pm
3sgte injectors are side feed are they not....
So no, don't put them in the 4agze...they wont fit.
--Sykotic
slighty_sykotic
Postby themaleman » Sat Jul 22, 2006 12:12 am
lol thats a very good point.
4agte ae92 Levin
a15 powered sj410
themaleman
Postby Akane » Sat Jul 22, 2006 2:24 am
440's would be pushing it for 200kw @ wheels.
Depending on when you need them, I will be selling my 540cc Supra injectors.
Postby sergei » Sat Jul 22, 2006 1:11 pm
ST165 injectors are top feed. low impeadance ~440cc.
Postby themaleman » Sat Jul 22, 2006 1:18 pm
yea thats wat i thought
4agte ae92 Levin
a15 powered sj410
themaleman
Postby Adydas » Mon Jul 24, 2006 10:22 am
Ive got some top feed 3sgte injectors to.
Adydas
