Hilux axle into an AE86 - what size ?
Postby beeker » Sun Jul 23, 2006 5:57 pm
What size (length) hilux/hiace axle do I need to find for a AE86 conversion ?
Anything i need to ask or check ?
Thx in advance.
94 DC2 Integra Race Car
02 M3 Race Car build
06 RS4 Avant
beeker
Postby beeker » Mon Jul 24, 2006 7:22 pm
bump
06 RS4 Avant
beeker
Postby crnkin » Mon Jul 24, 2006 7:38 pm
Im pretty sure what your trying to ask is if there is a direct fitting width for the ae86? theres not, unless you want mega flares. So you need to get it shortened. and as for axle sizes (ie diameter) i have no idea. sweet :)
deaf_homo "currrently yes"
crnkin
Postby Rick » Mon Jul 24, 2006 7:56 pm
Iam pretty sure a diff from a hiace is very similar in length to the ae86 one, they are also 5 stud which maks it a bit better for re studding or you can just use 5 x 114.3 rims, however using a diff from a hilux (like i did) will increase your track which can be quite benifital.
Postby sk1dlet » Mon Jul 24, 2006 10:04 pm
i found a hilux diff at my local wrecker that was 20mm overall wider than a standard starlet diff which in turn i am using fwd offset mags on the rear
82 4DR KP62 4AGTE MADNESS
98 RS200 ALTEZZA
sk1dlet
Postby Rick » Mon Jul 24, 2006 10:14 pm
sk1dlet wrote:i found a hilux diff at my local wrecker that was 20mm overall wider than a standard starlet diff which in turn i am using fwd offset mags on the rear
yeh I think the early 1980's rwd style Hilux's have shorter diffs Iam sure there has been alot of different length diffs made of the years.
Postby Volodkovich » Mon Jul 24, 2006 10:18 pm
there is a hilux that will fit, just a matter of finding one. They are in old late 70's, early 80s hiluxs.
There are multiple widths, i think 1380mm, 1430mm, 1480mm onwards. 1430mm out of mid 80's hilux will probably do you
Volodkovich
Postby drftnmaz » Tue Jul 25, 2006 12:18 pm
i use a 1420 one froma rn41 hilux in my ke70. my standard diff was 1400 witch i think is the same as the t series ae86 diffs.
most common/newer hilux are 1470.
drftnmaz
Postby Lloyd » Tue Jul 25, 2006 12:22 pm
Anyone know standard KE20 width since we're on this topic?
And are most Hilux diffs pretty much interchangable?
