St205/St215 air box sensor thingee
Postby DCEIVD » Thu Jul 27, 2006 3:01 pm
Does anyboady know what the sensor that is mounted to the factory air box is for?And more importantly can I remove it with out it having detrimental effects on my car?
I'm looking at having some custom intake piping made and want to know if I need to allow for this sensor or not.
2001 WRX STI RA...
DCEIVD
Postby slighty_sykotic » Thu Jul 27, 2006 3:10 pm
Probably air temp sensor at a guess?
--Sykotic
slighty_sykotic
Postby DCEIVD » Thu Jul 27, 2006 3:22 pm
Thats what I thought initially? But Im not so sure.
2001 WRX STI RA...
DCEIVD
Postby Jebus » Thu Jul 27, 2006 3:28 pm
Yeh or air speed, what does it look like? Is it a spear shaped thing?
Could always just insert it into one of your silicone joiners on your intake piping, thats what ive done with mine.
Jebus
Postby slighty_sykotic » Thu Jul 27, 2006 3:29 pm
Can you describe it?
( I don't own one of those cars )
--Sykotic
slighty_sykotic
Postby fivebob » Thu Jul 27, 2006 3:30 pm
I can't see any use for it as Gen III+ engines all have manifold temp sensors, which they should be using for fuel and ignition compensation.
However, though it might not be used to determine fueling and ignition, I don't know if removing it will cause the engine check light to come on or not. I guess you could just replace it with a 2.5kohm resistor and the ECU would think that the air temp was 20°C all the time.
Postby slighty_sykotic » Thu Jul 27, 2006 3:33 pm
Well, my 1st gen afm gze made a temp sensor in the afm, aswell as another seperate air temp sensor in the manifold.
I'd say tee it into the new intake, or if not, then do as he ^^ said, replace it with a resistor.
--Sykotic
slighty_sykotic
Postby fivebob » Thu Jul 27, 2006 3:35 pm
Jebus wrote:Yeh or air speed, what does it look like? Is it a spear shaped thing?
It's the spear shaped thing, but it's definitely a temp sensor. Actually it's the same sensor that the SW20 uses for engine bay temp, which everyone disconnects to switch the I/C fan on permanently :wink: .
Postby DCEIVD » Thu Jul 27, 2006 3:42 pm
Yes the spear shaped thing. No sorry I do not have a picture of it. But fivebob knows what I'm on about.
Just a friend of mine has it disconnected on his 215 and I was curious as to what it was - he doesnt seem to have any adverse affects from his ecu?
2001 WRX STI RA...
DCEIVD
Postby RunningRich » Fri Jul 28, 2006 9:07 am
It is an intake air temp sensor.
Given that it goes directly to the ECU, disconnect at your peril.
http://gtfour.supras.org.nz/pics/ECU2.pdf
That said, it is not uncommon for one SW20T I know of to spit it out, with no noticeable difference in operation. I suspect it is just an outside air temp compensator.
Richard
RunningRich
Postby DCEIVD » Fri Jul 28, 2006 10:02 am
No worries - allow for it I will... :)
2001 WRX STI RA...
DCEIVD
