I did a bad thing
I did a bad thing
Postby EarthwurmJurm » Thu Jul 27, 2006 7:08 pm
To cut a long story short, I was changing my spark plugs and overtightened the plug on the 4 cylinder and sheared it off.
Is this going to cost me shitloads ?
what should I do ? :(
EarthwurmJurm
Postby Dell'Orto » Thu Jul 27, 2006 7:17 pm
So you've snapped the plug off at the thread? Or is the hex still there?
Postby Pies » Thu Jul 27, 2006 7:26 pm
thats ok man. ya still have 3 cylinders. as long as there is still some spark plug sealing that cylinder off it will run sweet as. just take a speaker wire from the coil to whats left of the spark plug and bobs ya aunty! :D
Current Rides:
Pies
Postby EarthwurmJurm » Thu Jul 27, 2006 8:22 pm
the hex is still on whats left of the plug, as well as the bit underneath it where the metal thread covers the ceramic.
pies I will give it a go.. i tried to start it up after it happened and it sounded horrible :S
EarthwurmJurm
Postby slighty_sykotic » Thu Jul 27, 2006 8:45 pm
lol... Dont listen to pies.
Get a air compressor and blow all the shit (bits of spark plug) out of the hole, then get a spanner onto the hex and get it out.
Just blow the shit out first.
You don't want it in the motor.
If you think you might have some, send ALOT of air down the spark plug hole after you have taken it out to make sure there is nothing left, then nice new plug and do it up just a bit.
--Sykotic
slighty_sykotic
Postby EarthwurmJurm » Thu Jul 27, 2006 9:00 pm
the hex is on the part of the plug that isn't stuck in the cylinder tho?
EarthwurmJurm
Postby EarthwurmJurm » Thu Jul 27, 2006 9:09 pm
as you can see in this pic
the one on the left is the culprit obviously.
EarthwurmJurm
Postby slighty_sykotic » Thu Jul 27, 2006 9:17 pm
o....
I would try the second part of my post then.
Blow SHIT LOADS OF AIR down there, with a nozzle.
Really high pressure, worked for me to clean it.
I hope like $&#$% you havn't listened to pies and tried to start it.
--Sykotic
slighty_sykotic
Postby slighty_sykotic » Thu Jul 27, 2006 9:18 pm
no wait... the thread is still there... Hmmmm,
can you get it with pliers?
Then blow it...
--Sykotic
slighty_sykotic
Postby Adamal » Thu Jul 27, 2006 10:11 pm
Sykotic likes blow jobs!
Yea, that will require a bit of work to get out. If you've tightened the thread that much, then its gonna be stuck in there good. I'd say let it soak in some CRC before you try anything.
Postby Ae92typeX » Thu Jul 27, 2006 10:11 pm
a BIG easyout or similar should get it out fairly easy.
then I'd get a small hose and tape it onto a vacuume cleaner to suck anything which may have fallen inside.
and next time, follow the instructions for putting in a plug, they dont need much torgue really, especially not that much, you are lucky it didnt strip the thread really.
Ae92typeX
Postby RS13 » Thu Jul 27, 2006 10:15 pm
Damn, I've never seen that before! I've seen threads stripped on heads.. but never a plug that completely broke apart! I'd use an easyout, its a little punch-like device with a hex on top, that you whack into the hole, and unscrew it.
RS13
Postby Caveman » Thu Jul 27, 2006 10:17 pm
What sort of plugs were they? how hard did you tighten?
Reminds me of
"A good rule of thumb is to torque it till it snaps, then back off half a turn" :lol:
AW11 Track Toy
Formerly known as 1998
Caveman
Postby 4000GT » Thu Jul 27, 2006 10:20 pm
Easyoutsare shit and will likely shatter when trying to undo...
Find someone with some welding skills and weld onto the thread and unscrew it if you have the room to.
Supra MKIV Aerotop (UZA80FTE conversion) STATUS: 3 months to go!
Nitrous is like a hot chick with a STD..... you know you wanna hit it, but you are afraid of the consequences.....
Free online business and reporting tools visit www.e-solver.com
4000GT
Postby Ae92typeX » Thu Jul 27, 2006 10:24 pm
Ive had plenty of success with easyouts in the past.
cheap ones are crap, but for the size of the hole this will have a decent one, of a fair size should be fine.
I agree welding would be alright to, if space permits
what engine are we talking about here?
Ae92typeX
Postby EarthwurmJurm » Thu Jul 27, 2006 10:29 pm
I didnt think I was doing them real tight, I was holding the top of the wrench not even the handle so there wasn't much leverage.
They were quite tight when I undid them but im guessing now that's because they were hot and expanded.
I guess I will have to take the rocker cover off before I can do anything as there is quite a bit of distance between the hole at the top and the plugs.
The engine is a blue top 4age and NGK plugs
sykotic I started it for literally 2 seconds then turned it off.
I'm thinking this might be a job for the mechanic.. I'm pretty newbie. : P
EarthwurmJurm
Postby Adamal » Thu Jul 27, 2006 10:42 pm
EarthwurmJurm wrote:I'm thinking this might be a job for the mechanic.. I'm pretty newbie. : P
You are very wise.
Postby EarthwurmJurm » Thu Jul 27, 2006 11:01 pm
thank you sir : )
EarthwurmJurm
Postby Pies » Thu Jul 27, 2006 11:09 pm
You are very wise, for not listening to pies. OMG i rhymed! HOLY CRAP! *shits himself*
:wink:
Current Rides:
Pies
Postby Dell'Orto » Fri Jul 28, 2006 12:14 am
Damn, I've seen Champion plugs shit themselves in a similar fashion before, but not NGK.
My advice to you would be to take it to a mechanic if you're not confident trying to get it out, you might be able to easy out it.
