Stealer Of Souls wrote:That torque figure... That's at the wheels right?
How do you guesstimate the torque at the flywheel? Divide by the final drive then add a bit back on for losses?
So say around 340Nm @ flywheel?
IH8TEC said: i tried dummy fitting my new turbo tonight, and it wouldn't fit with that manifold i got, so it will be off to dan to get one made, the turbo is huge, such a tight fit
Akane wrote:Are you guys running one of those pull type valves or whatever those HKS SSQV things? I was under the impression that it shouldn't leak as boost pressure rises it seals tighter or something.
trueno_20v wrote:hows that link going? i have to go with a link ver 5 now as haltech said the interceptor wouldnt be the best on my car, so hopefully with the link it still runs ok eg cold start etc, hows yours?IH8TEC said: i tried dummy fitting my new turbo tonight, and it wouldn't fit with that manifold i got, so it will be off to dan to get one made, the turbo is huge, such a tight fit
put a civic half size radiator in like me, ive got plenty of room even eith the oil filter on
matt dunn wrote:My one was also a basic turbosmart one. If it is the type where you adjust it from soft to hard, screw it round to soft and keep screwwing till the lid comes of. Put a spacer under the spring and try again.
I needed about 18mm of spacers. I used washers.
Matt
What Turbo are you upgrading to Brendon?, same as mine?IH8TEC wrote:i tried dummy fitting my new turbo tonight, and it wouldn't fit with that manifold i got, so it will be off to dan to get one made, the turbo is huge, such a tight fitso will be a bit longer till i get my results up
flygt4 wrote:
thats exactly what ill do , cheers for that. its a bit worn from being in such a stupid place so i cant tell what brand it is , but you use an allen key to screw it from hard to soft. it is blue like the turbosmart ones tho.
yeah link+ quad throttle bodies makes it quite difficult to have a good tune for part throttle applications , such as daily driving etc.
someone else may be able to explain it better than me , im no technical wizard![]()
it is possible to get a fairly decent tune from it , but it takes a lot of finetuning on the road after the dyno side of it. im pretty happy with mine now.
Oh Gutted!...Really Matt???I was under the impression that the the more boost you run the better they seal, thats why I just fitted one to minematt dunn wrote: The HKS SSQV BOV's are actually the worst type for leaking actually.
They are fine on low and mid mboost but they dont take high boost even though they apply boost to both sides of the diaphram
