No its not just the rods, as in, they are not the main reason an engine will spit them out the side.
Mr Revhead wrote:No its not just the rods, as in, they are not the main reason an engine will spit them out the side.
while that can happen in engines, its not the cause of the blacktops issues. it is quite simply the rods them selves
Mr Revhead wrote:rod stretch.
Mr Revhead wrote:yes.
the 1st blacktop i saw with the ventilated block had just that. TRD bearings and ARP rod bolts.
put a hole in both sides of the block
RedMist wrote:Mr Revhead wrote:rod stretch.
So your saying that in a blacktop rod break situation, the piston slaps the head?
