Hi, I am about to convert my 86 GA70 Supra auto to a manual and in order to do so I bought an entire 88 ga70 manual to strip the bits off. The mechanical side of the swap is not a problem as I have completed this type of thing before and it is very well documented on various websites. What I am after is solid information about the wiring side of things, so that I don't have to start from scratch (like on my civic....but thats another story). I will obviously have the manual ECU, would it be advantagous to use it? If so do I have to change the whole body loom in order to do so? The donor car has a digital dash, which I would like to use (I am an 80's child!) I believe you have to change the 'dash loom' in order to do so. Is the so called 'dash loom' a separate plug and play affair? Would it be easy to connect the engine loom and dash loom out of the donor car with the body loom in my existing one? (This way I would get the dash and the manual ecu). Sorry for all the questions, any experiences/info/links would be appreciated (doesn't need to be 1ggte specific)
PS No 'get a decent engine' replies thanks, I have heard it all before which is why I am doing this in the first place. Maybe I am a fool.....time will tell.
