3SGTE temperature
3SGTE temperature
Postby Boosted_162 » Tue Aug 08, 2006 1:57 pm
Hey guys,
In my new ST185, the temperature takes bloody ages (usually at least 15mins of open road driving!) to reach normal operating temp (around halfway) and sometimes runs cooler than it normally would.
Am i right in thinking that the thermostat is at fault here? That its slightly open meaning its taking ages to heat up? Wanna find out as the thermostat seems to be an alternator out job! :?.
Also, im pretty certain the radiator cap is faulty, its showing same signs as my last GT4. Could this be the problem? I bought a new one today, but its wrong so ill get a new one tomorrow.
Cheers for your help :)
Postby sergei » Tue Aug 08, 2006 2:33 pm
Most like to be thermostat jammed open.
With the cap, it pays to change it once in a while...
Postby Boosted_162 » Tue Aug 08, 2006 2:54 pm
Ok, ill go in and get the right cap tomorrow.
If the thermostat was jammed open, would it run colder all the time? Cos sometimes it goes to normal temp? Or is it just working on occasions?
Cheers :D
Postby groupagt4 » Tue Aug 08, 2006 2:58 pm
i wouldn't say its jammed open probably jus opens too early you can chech it by removing it and heating it up in a saucepan with some water and a thermometer but if i was you ill jus replaace it quick and easy and it wont hurt to flush you radiator too since your gonna have to drain it anyway
groupagt4
Postby Boosted_162 » Tue Aug 08, 2006 3:01 pm
Well considering it is an alternator out fix, i wont bother checking it. Ill just get a new one from Warwick, and replace everything. Sucks not being able to drive hard cos it isnt warmed up properly :cry:
Postby groupagt4 » Tue Aug 08, 2006 3:22 pm
yea thats the downside of a gt4 their sh*t to work on
groupagt4
Postby RunningRich » Tue Aug 08, 2006 4:51 pm
Huh? You can't get an alternator that is much easier to remove that a GT-Four? It takes about five minutes??
You are a pack of pansies...
Richard
http://gtfour.supras.org.nz
RunningRich
Postby Boosted_162 » Wed Aug 09, 2006 1:05 am
Haha, its not so much that its hard to do, its more the fact its my only car that goes, so im limited on time to work on it as im working 6 days a week currently.
Ill change the thermostat when i have time, hopefully that will fix it. Cheers for your help guys :D
Postby TRIKI » Wed Aug 09, 2006 10:02 pm
my st185 seems to be doing the oposite, It reaches full temp just at idle after about 10minutes, and its sits at about just over half way on the guage. When should the 2 fans at the front operate and do the operate together?
TRIKI
Postby AJz » Thu Aug 10, 2006 12:37 am
my temp gauge only goes up to 1/3, and never really gets any higher than that. I havnt really looked much further into it, but im sure something needs replaced. Although disabling the VSV will get rid of that pansy 5psi while the car warms up.
I had vtax :(
AJz
Postby TRIKI » Thu Aug 10, 2006 8:01 pm
my fans arnt working at all, one of them was when i bot the car about 4 weeks ago, i checked the fan fuse and its fine, i was thinking is there anyway i could have effected anything when i installed the head unit, because the aircon is pretty close.
TRIKI
Postby groupagt4 » Thu Aug 10, 2006 9:23 pm
gt-fours do take while to heat up sometimes if your not boosting it reguarly it takes a while.as for triki fans usually goes on jus after thermostat opens apprx.84 degrees shouldnt really go above halfway you may have a problem with you cooling system
groupagt4
Postby XS1V » Wed Aug 20, 2008 10:40 am
Definately thermostats if its not getting up to half way. I run no thermostat in the racecar and that will idle at 70' which would be around a third.
If the thermostat is stuck open it will drop sometime even right down to the bottom of the factory gauge on the motorway at night
Brad
ST205 Group A Rallye #2363
XS1V
Postby Twolitre » Wed Aug 20, 2008 2:07 pm
TRIKI wrote:my st185 seems to be doing the oposite, It reaches full temp just at idle after about 10minutes, and its sits at about just over half way on the guage. When should the 2 fans at the front operate and do the operate together?
If you're worried about your fans not working unplug the coolant temp sensor switch on the bottom of the radiator, this will make your fans run continuously, if they don't run with the plug out try a known good relay otherwise your fan itself is probably stuffed, I had to replace the radiator fan on mine.
Twolitre
Postby molex » Wed Aug 20, 2008 4:40 pm
Two years old.
molex
Postby Boosted_162 » Wed Aug 20, 2008 7:33 pm
XS1V wrote:Definately thermostats if its not getting up to half way. I run no thermostat in the racecar and that will idle at 70' which would be around a third.
Brad
Lol, bit late there Brad :lol: This was actually on the black one you've got, on its original engine.
Postby eViLoNe » Wed Aug 20, 2008 8:09 pm
My ST185 does the same sorta thing, it only ever reaches 1/3 of the way up the gauge, never any higher. I think I need to replace my thermostat :D
- 1990 Toyota Celica ST184R
- 1996 Nissan Skyline GTS25t
Ex:
- 1990 Toyota Celica ST185
eViLoNe
Postby kim0663 » Mon Aug 25, 2008 1:32 am
its good tho that these things stick while open other wise you'd probably be blowing head gaskets?
seen lots of hondas stick closed... havn't really seen 3S motor thermostats stick closed til date.
Anyone else?
Mr2 GT-S
330ci M
kim0663
Postby Akane » Mon Aug 25, 2008 3:37 am
kim0663 wrote:its good tho that these things stick while open other wise you'd probably be blowing head gaskets?
Anyone else?
4E-FTE / 4E-FE, both stuck open.
Postby kim0663 » Thu Aug 28, 2008 12:52 am
Ok from rummaging around, i 'co-incidently' found a brand spanking new thermostat for a 3sgte in my garage lol.
Ive done it with the motor out, havn't really done one on a mr2 with the motor in.
are there any c**ts that need to unbolt out for this thermostat/flush work to go smoothly? (other than the thermostat housing). Coz from memory, there shouldn't be nothing in my way but just want to make sure there isn't even before i get my lazy arse to the car to find i don't want to do it.
Car is pretty far away and i can't check it... Anyone ? 8O
Mr2 GT-S
330ci M
kim0663
