sergei wrote:I will make rig to simulate the operation, I still have to measure the flow it outputs. If the cold start injector will not work, I will use a solenid (probably boost control, it has got alloy internals) and a fine jet. BTW where I can get the sprayer suitable for my application?
I Imported a couple of W/I pumps outta the US capable of pumping 150psi. I also found a guy in the hawkesbay who sells suitable nozzles. I have his e-mail addy at home. which I will PM you tonight.
he carries two different nozzles, 1's flow is sufficient for 1 nozzle per port runner set up, the other is suitable for 1 or 2 to supply the entire engine, depending on how much you need of course
10-15% of fuel flow seems to be the going rate
Motorsport Bay of Plenty -
http://www.mbop.org.nz
