RS13 wrote:Cost. SR20DET's with 5spd gearboxes are going for over $3000 together, without ECU or anything. I'm sure you could buy a 3SGTE with loom, ECU, intercooler, throw some forged pistons in, buy a W5* with the 'S' bellhousing for a few hundred, and have spent around the same?
JustinSpiderholden wrote:
im sure a 1jz would fit in there with out butchering the firewire theres a ae86 gettin around auckland with a 2jz and they havnt had to touch the firewall
gmacrae wrote:Are you fools smoking something? (other than the pole)
I would think people in a toyota forum would be slightly better advised
The SR20 is one of the only 4cyl jap engines i'd never want to own, they were built to be cheap - that is all. Every other jap dohc 2l 4cyl on the road is better designed. Yes you can make them go fast, you can make a morris 1800 go fast if you really want to, but its still rubbish.
Mr Revhead wrote:well same goes for the 800+ RBs. and rotors etc etc.....
Users browsing this forum: No registered users and 35 guests
