lexus v8 motor
lexus v8 motor
Postby x_way2ez_x » Sun Aug 13, 2006 9:51 pm
will a standard lexus v8 handle low boost turbo or super charger? what are the internals like? any major weak points that deffently need to be upgraded?
thanx
x_way2ez_x
Postby Silent Knight » Sun Aug 13, 2006 9:58 pm
It'll handle low boost fine.
I've never heard of one blowing up/seizing because of turbos or a supercharger.
Major weakpoints I'm not too familiar with but AFAIK there aren't really major ones as such that could cause breakdown etc.
What sorta power/boost you planning on running?
Silent Knight
Postby CozmoNz » Sun Aug 13, 2006 10:00 pm
Injectors....
arnt they just on par for their n/a performance?
Rayne For President!
CozmoNz
Postby matt dunn » Sun Aug 13, 2006 10:05 pm
CozmoNz wrote:Injectors....
they are only mid 200's cc for flow, but there are 8 of them.
Matt
Postby CozmoNz » Sun Aug 13, 2006 10:12 pm
3sgte:
4x 540cc injectors
each injector injecting to 500cc's (4 / 2000cc)
1uzfe:
8x 250?cc injectors
each injector injecting to 500cc's (8 / 4000cc)
i can see where injectors will be a problem :P
unless yaknow, they can all take turns at injecting all 8 injectors to each cylinder :D
CozmoNz
Postby Silent Knight » Sun Aug 13, 2006 10:16 pm
1JZ has 380s and that *6 is only 2280.
I've seen the stock injectors put out 250kw @ tread in some of them. :wink:
Silent Knight
Postby deaf_rattle » Sun Aug 13, 2006 10:42 pm
and 7mgte injectors go in with very minimal modification, resulting in 8x440cc :wink:
Re: lexus v8 motor
Postby 4000GT » Sun Aug 13, 2006 11:01 pm
x_way2ez_x wrote:will a standard lexus v8 handle low boost turbo or super charger? what are the internals like? any major weak points that deffently need to be upgraded?
thanx
There are several out there. Try Lextreme for resources.
I am tossing up between a 1UZ Twin turbo and a NA-T in the Supra I am about to buy...
Supra MKIV Aerotop (UZA80FTE conversion) STATUS: 3 months to go!
Nitrous is like a hot chick with a STD..... you know you wanna hit it, but you are afraid of the consequences.....
Free online business and reporting tools visit www.e-solver.com
4000GT
Postby EVL GSXR » Mon Aug 14, 2006 4:47 pm
Mate just brought a Direct Bolt on Super Charger for his Lexus from the State's should be interesting once the Link Plus is Tuned. Be one bad ass Hilux :D
Also know of a Race Car running a Lexus (standard internal's) with twin GT28's pushing 600hp so yeah can be done
www.lowndvs.co.nz
1997 GSXR750 - 11.23 @ 128mph to date - Round 280kph Top Speed to date
http://toyspeed.blakjak.net/profiles/profile.php?id=793
EVL GSXR
Re: lexus v8 motor
Postby cr1mnl » Mon Aug 14, 2006 7:11 pm
thanx
1. Yes
2. Strong as. 6 Bolt mains. Beefy rods. Forged steel crank.
3. Injectors and ecu.
As stated www.lextreme.com has heaps of members with FI 1UZ's
http://toyspeed.blakjak.net/profiles/profile.php?id=708
Horsepowers for bragging, Torques for dragging...
www.ology.co.nz
cr1mnl
Postby the fallen303 » Mon Aug 14, 2006 7:13 pm
Silent Knight wrote:1JZ has 380s and that *6 is only 2280.
*holds up hand as example*
true house of JZ
Stay true to the origin
the fallen303
Postby x_way2ez_x » Mon Aug 14, 2006 8:51 pm
nah not looking at doin anything xtreme i came up wit a car i dont think any1 has dun (cold be rong) no of sumthing similar
be bought 10 - 12psi of boost
if i go turbo itl prob just twin tdo5's or tdo6's just small time
dont no wat supercharger if i do go that way
thanx for help
x_way2ez_x
Postby Dell'Orto » Mon Aug 14, 2006 8:57 pm
Err, twin TD05 or TD06's are hardly small time....depending on what sort of TD05, thats like 650-700hp of airflow...
Postby x_way2ez_x » Mon Aug 14, 2006 9:05 pm
prob just standard evo1 turbos or step them upto 20g compressor wheels
small time
x_way2ez_x
Postby Mr.Phreak » Mon Aug 14, 2006 9:05 pm
You still planning on putting this in a starlet??
Mr.Phreak
Postby x_way2ez_x » Mon Aug 14, 2006 9:10 pm
nah
sumthing quite abit different from a starlet
wat im looking at doin aint the brightset idea wont be accomplishing much stuff all speed aint the best looker just bloody xpensive to do
shold fit
x_way2ez_x
Postby Mr.Phreak » Mon Aug 14, 2006 9:19 pm
What.......the......$&#$%?
Mr.Phreak
Postby x_way2ez_x » Mon Aug 14, 2006 9:23 pm
yeah it aint goin into a toyota if i do it
but yeah
x_way2ez_x
Postby Alex B » Mon Aug 14, 2006 9:23 pm
x_way2ez_x wrote:nah
wat im looking at doin aint the brightset idea. Wont be accomplishing much. Stuff all speed. Aint the best looker just bloody xpensive to do,
shold fit.
Hrm, seems it still doesnt make sence....
Postby Silent Knight » Mon Aug 14, 2006 9:24 pm
Silent Knight wrote:Also 99.7325% of the time when people concider things on here they never end up doing it... :lol:
Please prove me wrong... :roll:
x_way2ez_x wrote:wat im looking at doin aint the brightset idea wont be accomplishing much stuff all speed aint the best looker just bloody xpensive to do
shold fit
Going by that it seems that you have problems with even the most of basic things such as using a keyboard. Which makes me think that you are even more likely to fall in the 99.7325% of people as referred to above...
Silent Knight
