I'm getting round 700kms to a tank in my skyline
HRT wrote:barryogen wrote:...is that if they are going to decline on the fact that the car was chipped, then the chip has to be a direct cause of the accident. if it wasn't a direct cause, then the claim should still stand...
Depends entirely how you want to look at it. The chip contributes to extra power which in turn can contribute to pretty much anything
deepsyot wrote:Get the car tuned by the right person and it wont be expensive to run.
misha wrote:That's boosting it
Dirtbag wrote:avatar
EVL20V wrote:yes, s13 crossmember styles way to go
Who tells people this crap? I have helped with several GTSt/A31/C33 5spd conversions, including converting my own turbo Cefiro, and I can tell you that the myth of the S13 crossmember fitting is absolute horseshit.
The manual and auto gearbox crossmembers are identical for A31, S13, C33, R32. The difference between manual and auto rwd turbo Nissans is that the crossmember mounting points on the transmission tunnel are about an inch and a half further up towards the motor (in the manual), although I have been told that an S14 manual crossmember has a longer flange and may bolt up, but I am yet to see someone try this. All of the conversions I have done/seen have used a modified auto crossmember, or an auto crossmember with an adaptor plate.
Identical.
This is what I had to rangi up to get the crossmember attached so that I could get around in the car. (Ended up selling it like that in the end, although I had an adaptor plate for it!)
Itsamirage, I'd like to see pics too. I sold mine due to getting into trouble with several local police, who (I know now!) live down my street, who were quite keen to see the Cefiro go! And the amount of fuel it consumed, $30 of 98 would get me about 10mins of thrash!
deepsyot wrote:I'm not sure what you were doing wrong or what parts you have been using but they are definitly different and the S13 does bolt up and I know this cos we have just put one in one of our skylines that has been converted from auto to manual.
RS13 wrote:deepsyot wrote:I'm not sure what you were doing wrong or what parts you have been using but they are definitly different and the S13 does bolt up and I know this cos we have just put one in one of our skylines that has been converted from auto to manual.
Pics or it didn't happen.
