Nice hp, when does boost start to come on, when does it reach full boost (rpm).
How does the wheel hp figer translate to at the engine.
What suporting mods does the engine have.
sorry for all the questions but just looking at the options A.
Cheer
Mr_procrastination wrote:What do you mean by enlarged IIRC???. Id read that the unit has very good spool up, and had seen a couple of dyno sheats on ATP's web sight that tended to show good spread of power from the turbo with the .64 AR exhaust housing.
And it is my understanding that the internaly gated version uses the T25 housing.
Any ideas about the external gated version with the T3 housing?
Akane wrote:What Lith said, is that the wheels and housings are mismatched on the internally gated ones, you get a huge GT30 comp side but you get a tiny T25 exhaust side, you might as well go all out with a proper GT3040R, like I said before. Small turbo have their places too, if bigger is better then you bought the wrong car.
Lith, coz CT20b is not extreme enoughSif want bearing failure from overspeeding, shaft snapping.
Mr_procrastination wrote:Hey Akane, sorry i ment smaller turbo being the gt28rs.
Mr_procrastination wrote:gen two, full rebiuld, custom sump, everything dynamicly balanced, lightened flywheel,linished and shotpeened crank and rods,je forged pistons with rings, milded porting on the head and a good polish, klford cams, custom inlet, custom exhuast manifold, removed dizzy, twin coil wasted spark ignition, removed tvis, link(but will change to megasquirt) 38 mm tial wastgate... think thats most of it, toyoace cluch plate HD presher plate, 3y bellhousing, w57 boxand more than a few years
Akane wrote:Mr_procrastination wrote:Hey Akane, sorry i ment smaller turbo being the gt28rs.
LOL why are you sorry, if I wanted to do the "mad big turbo stylez" I'd kept my old GT2540R, which supports 260rwkw+
Lith wrote:Thing is, a GT3071R can make more power and will spool at least as well
Akane wrote:Lith wrote:Thing is, a GT3071R can make more power and will spool at least as well
Maybe one day i'll get that and then i can roll with the big boys.
