Welding a turbo flange on a stock manifold
Postby Caveman » Thu Aug 24, 2006 12:18 am
Hi
Does anyone know how well a stock ex manifold with a turbo flange welded on will work? Not going for peak performance, just some good cheap fun :lol:
So anyone done it? What sort of results?
AW11 Track Toy
Formerly known as 1998
Caveman
Postby MrOizo » Thu Aug 24, 2006 9:20 am
YES!!! :oops:
worked all good..
got todd/V6Rolla in welly to do it for me.
Was cheap fun alright. cheap and short ;)
Please make sure you buy some patience along with intercooler, extra fuel, and some decent ignition timing (ie not 20^deg ;))
Lasted a whole 10 mins.... that included the warm up idling and the drive up the road with no traction in a AW11 tee hee heee
Dasmnnn i had pics some where but fuucked if i can find them now!
MrOizo
Toyspeed Legend
Postby MrOizo » Thu Aug 24, 2006 9:25 am
Ahhh..... here we go :D
MrOizo
Toyspeed Legend
Postby neo » Thu Aug 24, 2006 12:19 pm
ahhh that sounds like fun, I wish I had cheap cars and a paddock
neo
Postby Arthanon » Thu Aug 24, 2006 12:40 pm
Thats some uglieeeee welding.
Current Ride: 1998 GT Caldina 3S-GE BEAMS Goodness
Previous Ride: 1994 Curren 3S-FE Not so Goodness
Arthanon
Postby drftnmaz » Thu Aug 24, 2006 12:42 pm
Arthanon wrote:Thats some uglieeeee welding.
what? its looks ok for a mig. 8)
drftnmaz
Postby Grotty » Thu Aug 24, 2006 2:32 pm
i've seen a lot worse. welding to castiron is not a good idea thou if you want the weld to last.
Grotty
Postby RomanV » Thu Aug 24, 2006 2:44 pm
Do some 4AGE's come with a factory cast iron manifold? :?
Postby Jebus » Thu Aug 24, 2006 2:50 pm
Yep, all the 16v's
Jebus
Postby Caveman » Fri Aug 25, 2006 9:33 pm
Meh Ill just full power arc it on 8)
Cheers guys will let you how it goes (if it goes)
MrOizo: I heard you car spat a drive shaft? Did the engine blow up at all?
AW11 Track Toy
Caveman
Postby bluemaumau » Fri Aug 25, 2006 11:39 pm
dylan can you explain for the need for these answers?, did your manifold pop?
Postby Caveman » Sat Aug 26, 2006 1:50 am
bluemaumau wrote:dylan can you explain for the need for these answers?, did your manifold pop?
Haha nah its for a mate. Just mucking around really. I think hes going to go tubular but I recon this would work mint for the cost involved.
My manifold is schedual 40 steam pipe full arc welded. No way its breaking 8) It'll snap the studs outta the head before it cracks :lol:
AW11 Track Toy
Caveman
Postby vvega » Sat Aug 26, 2006 9:49 am
if you preheat the cast it wil not get hireline cracks
also make sure there is no carbon on the inside of the area to be welded
vvega
Postby 135007 » Sun Aug 27, 2006 3:55 pm
only fully weld the inside of the flange as well as the pre heat comment ant just sticth the outside! little welds with gaps between them!
better late then never aye!
135007
