6Speed Gear box - recon or second hand
Postby BZR4AGE » Sat Aug 26, 2006 4:33 pm
Hi there guys, I've just got my car back on Friday.....and the workshop told me the gearbox needs some attention. Actually the problem started even before i went to tune my car.
Is VERY HARD to shift to second gear, and third syncro is stuff. When it is cold, its make a crunching noise, but after a while when the engine is warmer, the problem seems to go away.
After the engine was done, it vibrates more than factory. I heard somewhere that a engine damper may solve the gearbox problem slighty, (but ofcoz not the crunching noise)
My question is, 1) would a engine damper help? 2) should I recon the gearbox, or try to get a second hand one. becoz I went to Kasper transmission, they test drove the car, and said "most of the syncros are out of place".
Anyone know how much a new set of gears would cost. i saw a while back someone on trademe selling a broken gearbox said something abt $800 for all the gears ex-japan. is that right??
or am I better off getting a second hand 6 speed??
And anyone recommendation to where to fix it??? I have some pretty bad experince with many gearbox shops. I am in auckland
Thanks in advance :P
BZR4AGE
Postby flat_0ut » Sat Aug 26, 2006 6:05 pm
if your not going to do it yourself its probably cheaper to get a second hand one
flat_0ut
Postby AceSniper » Sun Aug 27, 2006 1:06 am
rebuild it, you would pay 1k+ for another 6speed, that has 80k+? km onit... if its only syncros as it sounds like... get them fixed a 0km box is going to last longer even if it costs around the same
AceSniper
Postby AceSniper » Sun Aug 27, 2006 1:10 am
btw you wont need gears... only syncros
the cost will mostly be labour
AceSniper
Postby BZR4AGE » Sun Aug 27, 2006 1:28 am
cool cheers ace sniper
BZR4AGE
