Ae92typeX wrote:100% sure you put the clutch in the correct way round?
Release bearing & fork installed correctly?
bent fork?
HRT wrote:Is the slave cylinder moving far enough? Got enough fluid in it?
Quint wrote:Hmm get someone to lie under the car and then put ur foot on the clutch, get them to tell you wether the pushrod actually moves, My guess is that the fork isn't actually ON the carrier for the release bearing propperly, but get someone to check and iff the pushrod is moving the clutch fork, then thats where i'd look first, Did you make sure to put the little clip things on the forks fork and the carrier?
If the pushrod isn't moving that means your having interaction problems between cylinders, make sure the flared copper line bits are secured firmly into each cylinder and neither are leaking, If thats not the case te seals in one of your cylinders have probably given up the ghost.
