crispy'86 wrote:i'd be wary with what i've experienced with those looma. I'm currently helping out a guy who got his loom stripped by this same person and has no igf signal for the ecu , i've advised him i had same problem with my fxgt but that uses orig loom. The problem is same.................no spark.
crispy'86 wrote:The Igniter has to be earthed to body by bolt and make sure ALL your earths including ECU are earthed. Also if you have troubles pm me as i can have look at my redtop loom and advise you if you are missing anything.
jondee...cheers for that, for some reason that wire has been soldered onto the earth point that bolts onto the manifold. on another (unmodified) loom ive got this wire seems to go to the diagnostics box...does that sound correct? is it supposed to be earthed?
l1ttle_d3vil wrote:crispy'86 wrote:The Igniter has to be earthed to body by bolt and make sure ALL your earths including ECU are earthed. Also if you have troubles pm me as i can have look at my redtop loom and advise you if you are missing anything.
does it actually have to be attached to the body by a bolt? i've attached a pretty beefy wire to the bracket and run that to the body. would that not work the same?
and do you mean including the earths from the ecu, or including the ecu body itself being earthed out?
jondee86 wrote:Probably mistook the black wire for an earth. Yeah, I have a diagram that shows the tacho feed being connected to IG- in the Diagnosis Connector. Also seems to connect to the A/C computer and Cruise Control systems on some models. All the same, the tacho output should NOT be earthed.
Had a feeling it wasnt right, but would that effect whether the coil / ignitor fires or not?
Users browsing this forum: Bing [Bot] and 12 guests
