Paint Stripper - What works?
Postby wde_bdy » Sun Sep 17, 2006 12:15 pm
Tried some stripper yesterday and all it did was make a mess. What have you used and what worked? I got sold Resene brand, was a complete waste of time and didn't even really bubble the paint.
Callum
wde_bdy
Postby phat5k » Sun Sep 17, 2006 3:39 pm
break fuild does a great job! (if its not your car that is!)
i like desprung :) it makes titties bounce!
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1362
phat5k
Postby Bling » Sun Sep 17, 2006 5:39 pm
http://www.por15.co.nz/POR15Prod/paintstripper.htm
havent used it, but have used other products in the range and recommend
Postby Ae92typeX » Sun Sep 17, 2006 6:10 pm
used various brands. depending on age/type of paint to be removed, it often helps heaps to give the paint a little rough up with sandpaper. Ive found that can make a big difference in the effectiveness of the stripper
Ae92typeX
Postby suckymotor » Sun Sep 17, 2006 9:52 pm
i have been using the selleys stuff best place to get it is from the warehouse about $3 cheaper than any other places
suckymotor
TS Original Member
Postby no_8wire » Sun Sep 17, 2006 10:31 pm
blow torch...and I am serious...used it on a house we repainted! 8)
no_8wire
Postby malc » Sun Sep 17, 2006 11:09 pm
what exactly are you using it on?
car, house?
i'm guessing its a car seeing as how your asking in the tech section.
you wouldn't want to put a blow torch on a car panel :?
malc
Postby fangsport » Sun Sep 17, 2006 11:16 pm
there was 2-pac paint that hadn't be properly mixed when i bought the TE71, i tried heaps of things to get it off without much luck.
in the end i used lots of thinners and steel wool / scotchbrite pads. was a bloody gooey mess, but got it off the panels.
fangsport
Users browsing this forum: No registered users and 26 guests
