Pies wrote:
now how do i go about setting shims?
cosi wrote:Pressure test the head before you do anything else. There wouldnt be much point porting it unless you have a flow bench, clean up the casting marks on the intake runners if there are any. Make sure the combustion chambers are the same volume. Have someone cut the valve seats on a serdi, apparently 3 angle seats improve the flow of air into the chambers. Match the intake manifold to the head. Have the head decked/planed last. Maybe get some decent valve seats. Not sure what you can do about the valve guides on a 4age
CAMB01 wrote:Probably not a good idea to stick with the 4age shim and bucket as when i had my aftermarket cams in it rattled really badly, sounded like all 16 tappets were loose (i had rebuilt the head and set the tappets accurately as they were checked many times cause i thought they were loose).
The shim was rocking on the bucket, but still revved to 8000rpm no problems for about 10000km's then decided to pull them out as i got sick of the sound.
RedMist wrote:I race against a 4age built by Kelfords with very similar lift and duration to my shim under bucket solution. His standard bucket engine doesnt sound any different to mine, runs as smooth as mine on idle, in fact its hard to tell the engines apart (other than mine produces 2.5bhp more!)
And we are talking about 304 degree 415 thou lift cams. ( I think, although can't confirm as he wont give me details, his lift is slightly less) are you sure you didn't insert one of the shims upside down? They are convex.
In regards to the Toyota shim under bucket,
http://www.club4ag.com/faq%20and%20tech ... uning.html
RedMist wrote:CAMB01 wrote:Probably not a good idea to stick with the 4age shim and bucket as when i had my aftermarket cams in it rattled really badly, sounded like all 16 tappets were loose (i had rebuilt the head and set the tappets accurately as they were checked many times cause i thought they were loose).
