'81 Corona Questions
Postby Slinkylinks » Wed Sep 20, 2006 12:13 pm
Hi,
I've just got hold of an '81 Corona, I think tha'd make it an XT130?
First of all, its in very nice condition, but its de-reg. It's an auto, and I'd like to convert it to a manual.
Is there anyone round auckland who'd do this? How much would that be likely to cost, and what if anything do I need to cert it. Is this an easy conversion that I could do myself?
Also, I'm at some point going to be keen to put a new engine in it. I'm after an easy swap any ideas? I was thinking the Holden 202 engine (I've heard that goes straight in) a 4AGE or 4AGZE or 3T-GTE (it has a 3T engine at present)
Cheers for any help,
Matt
Slinkylinks
Postby AE85coupe » Wed Sep 20, 2006 4:33 pm
de-reg???
i'd say throw it away and get another one, costs a bunch to re rego
do the auto to manual conversion yourself, its piece easy
the holden 202 engine will not bolt straight in, and its a $&#$% ghey engine anyway
3tgte would be the easiest/cheapest option for you
or you could always put a nice 2tgeu in it, thats very very easy and cheap
AE85 Trueno *For sale*
Details of car here
AE85coupe
Postby 4age_rage » Wed Sep 20, 2006 4:35 pm
If you decide to sell it hit me up I'd be keen to buy it
4age_rage
Postby Slinkylinks » Wed Sep 20, 2006 4:46 pm
Ok, so we pass on the holden idea, figured it'd be pretty silly anyway.
I figured that since the car hasnt cost me anything, the bit to get it put back on the road is probably worth it (VTNZ quoted me $295 + reg)
So the gearbox thing. What should I be putting in it, and how do you go about it>? do they just bolt in? how do you do the pedals?
Slinkylinks
Postby AE85coupe » Wed Sep 20, 2006 5:20 pm
Slinkylinks wrote:Ok, so we pass on the holden idea, figured it'd be pretty silly anyway.
grab a t50 gearbox and driveshaft from a manual 3t corona, also get the flywheel, and the pedal box, you will probably have to drill a hole for the clutch master cylinder
everything pretty much bolts right in
Details of car here
AE85coupe
Postby fangsport » Wed Sep 20, 2006 7:36 pm
have a very good look around the tailgate hinges, pillar and gutters for rust, another common place for them to go is around the seam of the inner guard to chassis rail. these are structural points that could make re-vinning and issue.
as for converting to manual, get a T-50/3T flywheel clutch system etc and you're set. possibly have most of the parts you need.
fangsport
Postby Slinkylinks » Thu Sep 21, 2006 1:22 pm
Does it need to be certed at all (the gearbox) or can they just be swapped around with no one caring too much?
basicly I want to know if I have to do what before I get the car re-vinned or if I can do it after?
Slinkylinks
Postby AE85coupe » Thu Sep 21, 2006 2:20 pm
Slinkylinks wrote:Does it need to be certed at all (the gearbox) or can they just be swapped around with no one caring too much?
Do it after the vin
it only has to be certified if you fabricate gearbox mounts or cut the tunnel, which you will not need to do either of
but being manual may affect the vin, so i suggest doing it after you have a vin
Details of car here
AE85coupe
