lumpy idle in 20v?
lumpy idle in 20v?
Postby .:O4AGTZ:. » Thu Sep 21, 2006 9:56 pm
what is the best way to get a nice lumpy idle out of a 20v if possible?
.:O4AGTZ:.
Postby Leon » Thu Sep 21, 2006 9:59 pm
8O 8O 8O 8O 8O 8O 8O 8O 8O 8O 8O 8O 8O 8O
You're kidding, right?
Postby .:O4AGTZ:. » Thu Sep 21, 2006 10:02 pm
not tht i was aware of. i have no idea bout lumpy idles how u gt them wot engines you can gt them on etc. sorry just wanted to be enlightened is all
.:O4AGTZ:.
Postby Mr.Phreak » Thu Sep 21, 2006 10:07 pm
Put a rotor innit :lol:
Mr.Phreak
Postby Meadzy » Thu Sep 21, 2006 10:07 pm
aggresive cams
"Keeping it true to the JDM"
J-Spec Group
http://jspecgroup.com/forums/index.php
AE86,200sx,EG6
Meadzy
Postby Leon » Thu Sep 21, 2006 10:25 pm
.:O4AGTZ:. wrote:not that I was aware of. I have no idea about lumpy idles how you get them, what engines you can get them on etc. Sorry just wanted to be enlightened is all
A lumpy idle isn't the goal... A lumpy idle is a side effect of running an agressive cam, or a combination of cam, tuning, and petrol. You should hear the production WRC cars at rally NZ. They have a totally psychotic idle.
Or the car just could have a totally sh1tty tune, and be running like a bag of arseholes.
Postby Dell'Orto » Thu Sep 21, 2006 10:38 pm
Get a VVT switch ;)
The correct way however is to get cams with a fair bit of lift, duration and overlap. Generally cars with really rorty idles are shithouse as street motors as the cam tends to shift the powerband up really high so as to be unusable on the road :lol:
Postby method » Thu Sep 21, 2006 10:45 pm
Create a vacuume leak :lol:
PICS UPDATED DAILY
method
Postby tomo1985 » Fri Sep 22, 2006 1:27 am
just pull out some vacum hoses. The one attached to the lil back thing on the strut brace.
tomo1985
Postby RedMist » Fri Sep 22, 2006 8:20 am
Pull two plug leads. Preferrably on sequentially firing pots. eg 1 & 3, makes it sound real good like.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby xRyanx » Fri Sep 22, 2006 8:22 am
Lol at everyones replies
ADMIN EDIT: oversized sig image removed - way too large
Adamal wrote:This is XRyanX. His car is so low that he has to drive over speed bumps diagonally. HARDEN THE $&#$% UP XRYANX!!
xRyanx
