Brake Pad Replacement On ABS Brakes
Postby Muzzie » Tue Sep 26, 2006 9:46 pm
I've done a search, couldnt find anything. prolly not using the correct keywords on something.
All i wanna know is, when replacing pads on ABS brakes, can you just use a clamp to push the caliper piston back in as normal or is there something special i'm meant to do.
Thanks
Mobile Car Servicing & Audio Installation - Inquire!
I'm Not Dumb, Im Just Selectively Observant!!!!
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1036
Had flash sig, but too big for TS :(
Muzzie
Regular Poster
Re: Brake Pad Replacement On ABS Brakes
Postby Crucible » Tue Sep 26, 2006 9:49 pm
Muzzie wrote:I've done a search, couldnt find anything. prolly not using the correct keywords on something.
Thanks
clamp the brake hose and open the nipple, use a bottle to catch the fluid, you dont want fluid going back through the actuator or it may flick on the abs lamp, then your in trouble :wink:
Crucible
Real Life Mechanic
Postby Bling » Tue Sep 26, 2006 10:04 pm
yeah i've heard you can damage the abs valves (same thing?) when forcing fluid the opposite way to normal.
i've never clamped a brake hose tho, loosening the nipple on the caliper has always worked fine for me (on non-abs cars)..
Postby Santa'sBoostinSleigh » Wed Sep 27, 2006 9:02 am
ive never had any problems just forcing the calipers without pissing around
however yeah loosening the nipple sounds like a good idea
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby bluemaumau » Thu Apr 19, 2007 7:01 pm
bumping
how do you do that without braking it???
cant you just leave the line hooked up,
unbolt one caliper bolt and lift the caliper up,
remove old padsopen bleed nipple,
depress piston,
close nipple,
new pads in,
caliper back on,
bolt on,
open nipple,
bleed,
test drive
do you need to unhook any sensors or anything when doing abs cars???
Postby AE82 FXGT » Thu Apr 19, 2007 7:12 pm
You leave it hooked up. You clamp it on the rubber hose.
AE82 FXGT
Postby ChaosAD » Thu Apr 19, 2007 7:24 pm
Just remember to take the vicegrips off again before you take it for a drive lol
ChaosAD
Postby bluemaumau » Thu Apr 19, 2007 7:28 pm
oh ok, i still wouldve thought that would damage the line (i know you mean the rubber part)
Postby Bling » Thu Apr 19, 2007 10:22 pm
i'd say unless the line is in average condition, it should be able to handle being clamped briefly. The are designed to work under harsh conditions after all :)
Postby Pelo » Thu Apr 19, 2007 10:23 pm
Yeah you should use proper brake hose clamps, they are rubber tipped with a good spread of force. If you want to use normal vice grips put something soft on the tips...
Pelo
Postby AE82 FXGT » Thu Apr 19, 2007 10:39 pm
Real brake hose clamps aren't that expensive though, if you change pads your self then you shouldinvest in some
AE82 FXGT
