wrong extractors?
wrong extractors?
Postby repowered » Tue Sep 26, 2006 7:45 pm
hey
this guys made my 4-2-1 extractors.
isnt this totaly the wrong way - like how 1 -2 pipes are joined and 3-4
shouldnt it be like 1-4 and 2-3 joining up. how much difference does this make, he reckons none and has done a silver top like this before.
im told it makes it have funny sound to it.
http://homepages.slingshot.co.nz/~jimco/images/extractors2.jpg
this is how it should be?? am i right?
churz
Rollin!
repowered
Postby Jebus » Tue Sep 26, 2006 11:22 pm
SSUUUBBBBAAARRRUUUU!!!!!!!
Jebus
Postby repowered » Tue Sep 26, 2006 11:27 pm
Jebus wrote:SSUUUBBBBAAARRRUUUU!!!!!!!
i know that what some one else said it would sound like! fuk
Rollin!
repowered
Postby matt dunn » Tue Sep 26, 2006 11:30 pm
Primary's are in the wrong order,
and IMO the secondary's are too short.
matt
Postby repowered » Tue Sep 26, 2006 11:32 pm
matt dunn wrote:Primary's are in the wrong order,
matt
cheers he said he would change it if i want
so is that bottom pic how they should be made?
Rollin!
repowered
Postby matt dunn » Wed Sep 27, 2006 12:13 am
I would say yes,
and if i was doing it i would not make the two pipes into one untill about 1 foot or so in front of where the front of the seat would be.
Postby repowered » Wed Sep 27, 2006 8:33 am
matt dunn wrote:I would say yes,
yea that sounds alot better to me aye.
Rollin!
repowered
Postby fuel » Wed Sep 27, 2006 10:58 am
Each runner should be equal length too. Sounds like the guy has no idea what he is doing when it comes to designing extractors.
Even if you look on factory cast manifolds you will see numbers 1+3 and 2+4 are joined before going to the secondary or collector pipe.
LOUD NOISES!!!
fuel
Postby repowered » Wed Sep 27, 2006 11:16 am
fuel wrote:Each runner should be equal length too. Sounds like the guy has no idea what he is doing when it comes to designing extractors.
thats exactly what i showed him aye, we checked it out and hes doing it again. ive seen his 4-1 and they look pretty good, he doesnt do many 4-2-1
Rollin!
repowered
Postby KinLoud » Wed Sep 27, 2006 2:32 pm
Don't stress too much about primaries being equal length. Within 15 to 20% will work fine.
If there is some variation in length it helps to widen the power band a bit.
Ken
Ham
021 408 863
Postby repowered » Wed Sep 27, 2006 3:06 pm
KinLoud wrote:Don't stress too much about primaries being equal length. Within 15 to 20% will work fine.
Ken
Ham
021 408 863
sweet cheers man, ill print out that last pic and show him - i want it like that!
Rollin!
repowered
Postby Caveman » Wed Sep 27, 2006 8:36 pm
And if your running an o2 sensor mount it where the 2-1 collector is, not just on one cylinder.
AW11 Track Toy
Formerly known as 1998
Caveman
Postby repowered » Thu Sep 28, 2006 9:47 am
1998 wrote:And if your running an o2 sensor mount it where the 2-1 collector is, not just on one cylinder.
yep i know about that thankz, the ones that have been made and are on there now are downb y the 2-1 collector.
i told him i wanted them redone but he hasnt got the time at the moment so he just gave what he had made to me! said its nto worth anthing to him. so cars at the painters today getting front 1/4's and bonnet done.
dropped driveshaft off last night for shortening - get discount through work so hopefully wont cost too much.
Rollin!
repowered
Postby repowered » Thu Sep 28, 2006 9:48 am
yep i know about that thankz, the ones that have been made and are on there now are down by the 2-1 collector.
Rollin!
repowered
Postby strx7 » Thu Sep 28, 2006 7:02 pm
secondaries should be twice the length of the primaries shouldn't they?
Postby repowered » Thu Sep 28, 2006 11:28 pm
strx7 wrote:secondaries should be twice the length of the primaries shouldn't they?
oh ok thanks, nto sure if i should keep them and see how they go, i could wait untill he can do them again, or jsut get 4-1 which seems way easier to get premade. where do you buy 4-2-1 ae86 ones should be ok.
Rollin!
repowered
Postby Adamal » Fri Sep 29, 2006 12:30 am
I think you'd find stock exhaust manifold would prove more efficient :?
Honestly, looking at the quality of the build, it looks like it would fall to pieces. I wouldn't keep them on there for long!
Postby matt dunn » Fri Sep 29, 2006 12:42 am
Apparantly the stock exh manifold with longer secondaries is very good.
Postby repowered » Fri Sep 29, 2006 8:16 am
matt dunn wrote:Apparantly the stock exh manifold with longer secondaries is very good.
the stock monifold points down at a funny angle and it point right at the steering arm. my engine sits back by the firewall so its stuffs stock manifold. i could use it but there would ahve to be this big 90' then a step down to get under firewall.
no one knows where to buy 4-2-1 (tri-Y) extractors?
Rollin!
repowered
Postby QikStarlie » Fri Sep 29, 2006 7:08 pm
i made some out of coby 4-1's. extra pipe came from the local car dump and under the house..
half done
http://img.photobucket.com/albums/v178/ ... c_0016.jpg
2-1 bit
http://img.photobucket.com/albums/v178/ ... 000141.jpg
cost 0
QikStarlie
Users browsing this forum: Google [Bot] and 30 guests
