7M had a blown headgasket...
Postby UTERUS » Wed Sep 27, 2006 10:27 am
I am upto the point where all i need to do is put oil in it and start it up.
Should i....
Take the sump off, clean it out and clean out the oil pickup?
Do something else i dont know about yet?
I have about 8 litres of new oil, 3 oil filters and 2 bottles of the engine flush stuff which you put in the oil before you drain it to clean it out.
Do i need to crank the motor over without firing it for a certain amount of time to get the oil pressure up?
Thanks!
Simon.
UTERUS
Postby fuel » Wed Sep 27, 2006 10:51 am
Use some cheap oil and filter for the first oil change and drive it for maybe an hour max. Then put in a bottle of engine flush and let it idle for 10~15 minutes (do NOT drive it with engine flush in it) and then drain all the oil out.
Now do the 2nd oil change with good oil and filter and you should be sorted.
LOUD NOISES!!!
fuel
Postby big_boy » Wed Sep 27, 2006 3:47 pm
yes crank it with the ingction disconcted til the light goes out 1st & i would take the sump of & clean it but thats just me
big_boy
Postby Punter » Wed Sep 27, 2006 4:25 pm
I'd crank it with the spark plugs out, no load that way.
Though probably doesn't make much difference.
Punter
Postby Jason T » Wed Sep 27, 2006 6:31 pm
No need to remove sump
Make sure all the air breather pipes are clean (one behind alternator mainly)
Fill with cheap oil and run engine till warm for *&(^ sake dont drive untill running clean oil quality oil
Get her warm then drain and refill both water and oil pull off the lower rad house keep the antifrezze but fish out those bits of sand paper that would have killed your new water pump
Fill with new oil & new filter run till at normal temp THEN enjoy driving
Fixing Toyota's since '87
Jason T
Postby AE85coupe » Wed Sep 27, 2006 6:39 pm
anti-freeze can kill a new head gasket, so make sure you don't run any at first
AE85 Trueno *For sale*
Details of car here
AE85coupe
Postby UTERUS » Wed Sep 27, 2006 8:29 pm
Cheers guys, i will take all that into consideration :P
UTERUS
Postby Mr Revhead » Wed Sep 27, 2006 11:07 pm
how can antifreeze kill a new head gasket?
Postby mr pad » Thu Sep 28, 2006 9:12 am
It can stop the gasket from setting correctly.
mr pad
Postby Mr Revhead » Thu Sep 28, 2006 9:35 am
interesting that the only mention of that is on internet forums.
and not in any manufactors repair manuals.
Postby fivebob » Thu Sep 28, 2006 9:38 am
Can't see how antifreeze could have any effect one whether or not the head gasket seals.
Perhaps one of the proponents of the burgeoning internet myth may care to explain. :roll:
Postby AE85coupe » Thu Sep 28, 2006 10:14 am
sorry its not an internet myth
i'm going off what a local engine reconditioner told me
so i guess its a local engine reconditioner myth?
Details of car here
AE85coupe
Postby fivebob » Thu Sep 28, 2006 10:21 am
AE85coupe wrote:sorry its not an internet myth
Could be, I've never heard any engine reconditioner, or any mechanic, say that you shouldn't use antifreeze.
But you still haven't explained how it's possible for antifreeze to affect head gasket seal. I cannot see how antifreeze is even going to get between the mating surfaces of a properly prepared head and block.
Postby AE85coupe » Thu Sep 28, 2006 10:24 am
I actually have no idea why
just going off what i was told
guess if i had the choice i would not run anti-freeze for a bit, better to be safe than sorry and all that
Details of car here
AE85coupe
Postby fivebob » Thu Sep 28, 2006 10:28 am
AE85coupe wrote:I actually have no idea why
which is exactly how internet myths start :roll:
Which is why you should run antifreeze from the start, especially in an engine that has an iron block and aluminium head, avoid corrosion right from the start.
If it was such a problem then why do new engines come with antifreeze? Surely they would run them without it until the first service,. Also as Mr Revhead states why don't repair manuals say not to add antifreeze?
Postby AE85coupe » Thu Sep 28, 2006 10:58 am
...just going off what a reputable qualified engine reconditioner told me
i'm not saying its right or wrong, i'm saying there is no harm in doing what he says
oh and i'm sure your engine is going to corrode away and do some serious damage for the short amount of time you would not run anti-freeze :roll:
Details of car here
AE85coupe
Postby Mr Revhead » Thu Sep 28, 2006 11:03 am
every scratched a piece of aluminum and seen how long it takes to fade again?
Postby fivebob » Thu Sep 28, 2006 11:07 am
AE85coupe wrote:...just going off what a reputable qualified engine reconditioner told me
If hes so reputable and qualified then get him to explain why, and I don't mean saying that it stops the gasket from setting or some such other non explanation, I mean in terms of what the mechanism is that causes the issue.
If you don't know the why's of his recomendation, how do you know for sure it does no harm???
Ever heard of electrolysis between dissimilar metals?
Again I ask, why don't manufacturers, or for that matter publishers of repair manuals, state this to be the case. Without exception they say to use antifreeze.
Postby AE85coupe » Thu Sep 28, 2006 11:12 am
Mr Revhead wrote:every scratched a piece of aluminum and seen how long it takes to fade again?
yes i know what alluminium is like? and i know anti-freeze is very important
Details of car here
AE85coupe
Postby AE85coupe » Thu Sep 28, 2006 11:19 am
o.k, i'll ask him when he gets home
hey i'm really sorry, just trying to help the guy who made this thread
still can't see any harm in not running anti freeze for a short period, hell i've seen engines that have never run anti-freeze, they are corroded to hell, but they still function (toyota 4k's mainly haha)
and yes i know about electrolysis between dissimilar metals, you really are pathetically condescending
Details of car here
AE85coupe
