1998 wrote:On the turbo-IC section it looks like there is a sharp reducer which would probably cause a lot of turbulence.
themaleman wrote:yea its got a couple of sharp bends but i mean thats the best we could do for where it sits. the guy that made the exaust manifold 2 the turbo but the turbo in a pretty sh*t place haha but i think we've made the best of it aye. that black piece of hose was put there for the movement when the engine rocks backwards and forwadrs (as slight as it may b). the hose is radiator hose. do u think it will withstand the tempurature and pressure being right under the turbo?? thats my main concern with wat we've ended up with
slighty_sykotic wrote:seriously, how many psi is radiator hose... I had a big section of it, a big u bend from the turbo back towards the motor, and then back towards the front. (had to because of turbo position).
Now, on the dyno, the pipe wasn't moving at all, that was on 14psi. Will work fine. Mate had a rx7 that had alot of radaitor pipe in the setup, and it worked fine.
Sure its not shiney tho
--Sykotic
neon_spork wrote:1998 wrote:On the turbo-IC section it looks like there is a sharp reducer which would probably cause a lot of turbulence.
The flow in the pipe will be turbulent anyway, as a rule of thumb it takes 10 times the diameter of the pipe for an internal flow to fully develop. Entrance, exit effects and the bends will cause turbulence. You will get increased pressure drop from the reducer. Smoothing the inside should reduce the pressure drop, if you are interester in the relationship between pipe roughness, friction and turbulence check out a moody chart.
