Pic Needed - 1JZGTE BOV
Postby MrOizo » Thu Sep 28, 2006 8:20 pm
I'm using a BOV from a 1JZ that i have laying around..
anyone have a pic of one at all? need to know how it is plumbed up and all that shit.
thought i had it sorted but doesn open up when the throtle body is closed after boosting...
hmmm... opens up under vacuum if i release the little hose that comes from the vac/boost feed.
MrOizo
Toyspeed Legend
Postby Si » Thu Sep 28, 2006 8:31 pm
a jza70 style BOV?
i have one of those in the garage!
in my supra! which i didnt disown :P
ill grab a photo now for you sir
Current: , '96 SubaruImpreza
Si
Postby MrOizo » Thu Sep 28, 2006 8:50 pm
Si wrote:a jza70 style BOV?
Easy!!! looking through my photos of the JZA70 almost made me cry :cry:
I have found on so no worruies - thanks tho... i think the one i got is just stuffed or something.... hmmm or the one-way-valve is around the wrong way? :/
MrOizo
Toyspeed Legend
Postby Si » Thu Sep 28, 2006 9:18 pm
what are uusing it on?
Si
Postby deaf_rattle » Thu Sep 28, 2006 9:22 pm
st165 i presume, something alot lighter than a mk3 :P
i must say i did like adrians jza70, nearly made me want a mk3.
Postby MrOizo » Fri Sep 29, 2006 10:04 am
Si wrote:what are uusing it on?
Yeah - a ST165. I have figured it out tho... needs to be a plum back. well be plumbed back into between the turbo and AFM..
might just get a rice boys one and try that out. only opens when the vac is much more than the boost :o
MrOizo
Toyspeed Legend
Postby KE20 » Wed Oct 04, 2006 5:48 pm
you probly got it on backwards. on the bov you have the pipe end and the flange end. the flange end vents the pressure and the pipe end comes from the turbo.
the bov works the opposite of most bov's. the valve lifts in the direction of the preesure to let air out. they run a little one way valve between the 2 little vacume pipes on the bov.
Garage Dori
current cars; , 2JZGE-YN57R Hilux double cab, Ipsum Sport, 1948 Ford F1
prevous cars; JZX81 X2, LX80, , 1JZGTE-JZX81, KE20-3SGTE, KE35-4AGE, KE35-3A, KE30, KE36, TE71, AE85, AE86, KE70 X4, KE20, 1JZGE-VVTI-JZX100, GX90, CT170, VW(beetle) x 5,(Kombi) x 2, mazdas x heaps, +more
KE20
