Factory TV
Factory TV
Postby FST4RD » Fri Sep 29, 2006 8:36 pm
Tried searching but nothing......
My friend just bought a 97 BZ touring carib and it has a factory TV in it.
Is there anyway you can get it to work?? Is there some sort of band expander (like what he needed for the radio) to get it to work??
1983 Mitsubishi Starion
1995 Subaru legacy GT SW
FST4RD
Postby flat_0ut » Fri Sep 29, 2006 8:37 pm
sure its not gps?
flat_0ut
Postby FST4RD » Fri Sep 29, 2006 8:40 pm
It's GPS, TV, CD, MD, Radio
FST4RD
Postby fuel » Fri Sep 29, 2006 9:11 pm
It will be NTSC system, unless you have some sort of NTSC feed for it then you wont be able to use it here as we use the PAL system.
LOUD NOISES!!!
fuel
Postby FST4RD » Fri Sep 29, 2006 9:17 pm
Can you get converters from NTSC to PAL???
FST4RD
Postby Emperor » Fri Sep 29, 2006 9:20 pm
NTSC and PAL are only the colour systems.
NTSC TV's work here in NZ, so I don't see why car ones cant.
But I don'think there's any converter etc available.
Emperor
Postby FST4RD » Fri Sep 29, 2006 9:34 pm
Weird that the TV doesn't work........
Does anybody know if there are inputs in the back for a DVD player??
FST4RD
Postby Emperor » Fri Sep 29, 2006 9:37 pm
We got TV 3 working in an RVR once, I sat on dads yard and watched the Teletards!
Emperor
Postby FST4RD » Fri Sep 29, 2006 9:41 pm
Apparently the car yard guy said that the frequency or "tv waves" are different like the radio waves???
FST4RD
Postby matt dunn » Fri Sep 29, 2006 10:06 pm
FST4RD wrote:Apparently the car yard guy said that the frequency or "tv waves" are different like the radio waves???
Yeah same as the radio's. NZ radio's go from 88 to 108 or what ever,
and the jap ones go from 76 to 88.
Same deal with tv's, except there is no such thing as a TV expander we have come across yet.
Postby Mr.Phreak » Fri Sep 29, 2006 11:13 pm
Emperor wrote:NTSC TV's work here in NZ, so I don't see why car ones cant.
Since when??
Mr.Phreak
Postby sergei » Sat Sep 30, 2006 1:47 am
The problem is not in colour format but frame rate (and slightly different resolution), PAL in NZ works at 50Hz interlaced, while NTSC in japan works at 60Hz interlaced. So basically it will show "moving frames" and B&W...
Postby Akane » Sat Sep 30, 2006 5:30 am
There ARE converters out there, but it's so stupidly expensive, crap quality, you're way better off just getting the whole PAL system.
Remember kids - NTSC = Never The Same Colour :twisted:
