Turboing a N/A 3sge.
Postby Adydas » Sun Oct 01, 2006 5:11 pm
My issue is the Idle up, im using a turbo manifold and throttle body but ive found the idle up wont fit as it would hit on the cam cover.
Im using a Aftermarket ecu so can i just block up the hole for the idel up or does it need to operate? ( ie the ecu cant compensate without it? )
Adydas
Postby Wildcard » Sun Oct 01, 2006 6:47 pm
Comparing to my gen3 3SGTE and 3SGE , the problem is you have the NA idle up assembly.... the orientaion is totally different unfortunately
Wildcard
Toyspeed Founder
Postby Adydas » Sun Oct 01, 2006 7:12 pm
pix plz....
Adydas
Postby Caveman » Sun Oct 01, 2006 7:37 pm
The only problem ive found with no cold idle up is the car always stalls if the battery is a bit down and the alternator is in charging.
Otherwise just give it a little throttle on startup and its fine.
AW11 Track Toy
Formerly known as 1998
Caveman
Postby Wildcard » Sun Oct 01, 2006 10:34 pm
A Gen3 3sg't'e will stall intermittently when coming off the throttle without one, I speak from my experience unfortunately as after my engine went back in the bypass mechanism had siezed.
Wildcard
Toyspeed Founder
Postby Adydas » Sun Oct 01, 2006 11:34 pm
so how do I fix it ???
Adydas
Postby Adydas » Mon Oct 02, 2006 9:07 am
Trust you to throw a spanner in my works Ben...
So comon bright sparks how do i get past this?
Adydas
Postby suberimakuri » Wed Oct 04, 2006 10:41 am
idle up is for babies... or just 3s.
itbs on any motor doesn't seem to need idle up, or stock manifold on 4age.
how can you stall a motor on standard ecu?
suberimakuri
Postby Akane » Wed Oct 04, 2006 11:45 am
Do it the Akane way, drill a hole in the butterfly to let some air in for idle!
Postby Adydas » Wed Oct 04, 2006 4:05 pm
Karl_Skewes wrote:idle up is for babies... or just 3s.
Im not using a standard ECU.
Adydas
