nite b wrote:8.9-1 & smallport head, you wont look back. Low comp is cool but always end up feeling 'laggy', even with conservative turbo. Power will be bit more linear and well suited to what you require. 18psi on a good tune & medium size turbo etc, will net you easy reliable 200kw@wheels. Nice accomplishable goal, sounds good!
IH8TEC wrote:just get a tvis one and dont use the tvis plate with the butterflies,
Mr Revhead wrote:no the ports dont match up.
make one you pussy
IH8TEC wrote:well not sure if they make smallport tvis manifolds.
the manifold on my car is a bluetop tvis one without the tvis plate in there, so no butterflies, yes it has twin holes for each inlet on the manifold and the head has 1 each cyl. but they line up.
could put money on it that a smallport tvis one would line up with a smallport head.
matt dunn wrote: But I dont see why it would not make as much or more power than the lower comp one.
